ltljohn Posted February 11, 2009 Share Posted February 11, 2009 Working on the wife's 97 F650ST. The ignition is stuck won't turn, I tried the WD40 etc no luck. I am trying to remove it. I have all of the screws/bolts out of the ignition assembly, the electrical section has been removed but I can not figure out how to remove the rest of it. It appears to have some sort of pin on the left side of the housing but I can not figure out how to remove it. The whole assembly is loose and pivots a little bit on the pin. Clymer manual is no help Link to comment
ltljohn Posted February 12, 2009 Author Share Posted February 12, 2009 Found an answer over at The Chain Gang Link to comment
