Need some help with seats
TracyPrier
Hi all
I just picked up my new bike, a 1997 R850R... such a great bike :)
One thing I want to do is add some height to the seat as I'm a wee bit scrunched up.
Adding seat jacks isn't an option on the R.
From what I have read the F650 seat has the foam attached to the cover not the base.
Does anyone know if this is a general rule with BM stock seats? Is the R likely to be the same??
Also, has anyone fitted footpeg lowering blocks to an R and did it effect the amount of lean before peg scrape much if at all??
appreciate any help with this
Tracy
I don't know about the upholstery, but just in case, do you know that the front half of the R850/1100R seat is adjustable to three different heights? If you lower the footpegs you will be able to scrape them in turns. Whether this is a problem depends on your riding style.
Thanks guys, the first thing I checked was the seat... and it's already at the top.
As for riding style... well although i am not a knee-down kind of rider I certainly do like to tip the bike over in corners.
Might try the seat first and leave the pegs alone for now.
Cheers
Tracy
You may want to check the part number of the seat.
Not sure if there's a low version out there that fits it, but maybe.
If so, a standard would give you an inch or so.
If not, many options to rebuild, even a local upholsterer could add some foam.
Remember to look at widening and not just raising hte saddle height.
Best wishes.
If it's like the R1150RT you can also add spacers, I made mine out of a sheet of alum., to raise the front of the seat.
cheap, higher, and more comfortable...........for me.
