chasgrips45 Posted February 9, 2009 Share Posted February 9, 2009 Where on the forum can I check on some procedures pertaning to a clutch replacement? thanks Link to comment
Mike T Posted February 9, 2009 Share Posted February 9, 2009 Where on the forum can I check on some procedures pertaning to a clutch replacement? thanks Do a search on "spline lube" or "clutch replacement" There should be a bunch of stuff. Also, the Avdrider.com Hall of Wisdom section has some good info with photos. Link to comment
Bob_Minor Posted February 10, 2009 Share Posted February 10, 2009 Whe I did the clutch on my '96RS, the best information came from the factory manual with Haynes as a good supplement. Link to comment
awagnon Posted February 11, 2009 Share Posted February 11, 2009 If it's for your RT, I have a six page checklist for lubing the splines, which is essentially the same procedure. I can email it to you if you send a pm. Also, there is a good video on spline lube and clutch replacement for the 1100RT. It's about the same procedure except for the mechanical rather than hydraulic clutch throw-out. Also, I prefer the BMW shop manual on CD over the aftermarket manuals. You can find it floating around the internet. Link to comment
Mulepick Posted February 11, 2009 Share Posted February 11, 2009 Yep, just use the search function under a number of topics and also check the tech link. I had to replace mine shortly after I bought it (used/salvaged) and those sources were a real help. bob Link to comment
chasgrips45 Posted February 13, 2009 Author Share Posted February 13, 2009 It`s for my 2000 R1100rs Link to comment
Rich06FJR1300 Posted February 13, 2009 Share Posted February 13, 2009 same as the RT with less tupperware removal. Link to comment
