Jerry Johnston Posted February 6, 2009 Share Posted February 6, 2009 There's a free program that is very simple and easy to use called Freerip that may interest many of you. I've tried it out and it couldn't be easier to use. www.freerip.com Link to comment
Effjay Posted February 7, 2009 Share Posted February 7, 2009 Another recommended program that enables free ripping as well as creating playlists from MP3 format is Media Monkey Using MM, I created several playlists by genre and uploaded to Zumo SD card. I also burned CDs for my truck using same... Jeff Link to comment
velomoto Posted February 7, 2009 Share Posted February 7, 2009 iTunes - free, works, available on PC or Mac, rips to many formats besides mp3 Link to comment
Jerry Johnston Posted February 7, 2009 Author Share Posted February 7, 2009 I just found out that Windows Media Player 10 also works. The freerip also makes ring tones if needed. At least all the programs mentioned above make you less dependent on MS. Link to comment
smiller Posted February 7, 2009 Share Posted February 7, 2009 I'd suggest using a program that utilizes the LAME MP3 encoder which is pretty widely regarded to be the best available right now. FreeRip and MediaMonkey do, iTunes and WMP do not (and the iTunes MP3 encoder in particular isn't considered to be the greatest.) This is admittedly a small consideration as any audible differences that might exist are likely to be very small, but just FWIW... Link to comment
George Brown Posted February 8, 2009 Share Posted February 8, 2009 Another recommended program that enables free ripping as well as creating playlists from MP3 format is Media Monkey Using MM, I created several playlists by genre and uploaded to Zumo SD card. I also burned CDs for my truck using same... Jeff ++1 to Media Monkey Link to comment
