Bruce H Posted February 5, 2009 Share Posted February 5, 2009 I would like to bleed the brakes on my 07 GSA. I don't beleive this bikes has servos like the instructions on Jim's video. Is this brake bleed straight thru where I don't have to take the tank off just fill the resivor and bleed at the wheel cylinders? I did the oil and filter yeaterday (using a BMW filter, pun intended) how do I reset the oil light? Link to comment
johnlt Posted February 5, 2009 Share Posted February 5, 2009 It depends if it is ABS or not. My 06 GSA is not ABS and it is a simple matter to change fluid and bleed them. Link to comment
Bruce H Posted February 5, 2009 Author Share Posted February 5, 2009 It does have ABS Link to comment
Mr_Ed Posted February 5, 2009 Share Posted February 5, 2009 It depends if it is ABS or not. My 06 GSA is not ABS and it is a simple matter to change fluid and bleed them. I thought the key point was if it was Servo or not (versus ABS).. I've yet to flush my own but I was told by my local shop that since I didn't have Servo on my 07 GSA that bleeding the brakes is cake. Just one circuit for the front and another for the back. Link to comment
Bruce H Posted February 5, 2009 Author Share Posted February 5, 2009 I flushed one circut for the front and one for the rear today however the anual check sheet I have says to check the ABS wheel circut and a control circut. I don't think this bike has that but want to confirm. I have an 03RT with servos and have done those but this one is different. I bought Jim's video but his bike has servos. Someone out there will know for sure. does anyone have a link to a maintenance schedule for the 12K, 24K and so on service? I have only the anual service sheet. Link to comment
marcopolo Posted February 5, 2009 Share Posted February 5, 2009 does anyone have a link to a maintenance schedule for the 12K, 24K and so on service? I have only the anual service sheet. Try A&S BMW, or BMW Canada. The maintenance schedules are available there as PDF files. Bear in mind that some changes made via tech service bulletins may not be reflected in these versions. http://www.bmw-motorrad.ca/En/ http://www.ascycles.com/bmw_motorcycle_service_and_maintenance_schedules.aspx Link to comment
