changing plugs 1200 RT
trek
Not really but keep in mind, it takes a thin-walled socket to fit over the plug AND into the plug hole. Some standard sockets will not fit into the hole. I use a Chraftsman that seems to work fine. You also need a plug-cap puller. I think the bike comes with a plastic one but many buy a stronger metal version. You can also use pliers "carefully" in a pinch but its really not the right tool for the job.
It's a good idea to have a lock-the-socket on type of extention so you don't pull off the socket when taking the plug out....For plug sockets, I have a Snap On #S9706KA but you can probably find a thin walled one much cheaper at Harbor Freight......
this is the socket you need:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91705
From 2006 at least, there's no plug wire puller provided with the bike. Marc Parnes makes a metal one. I've used it successfully several times, but also busted the little plastic lip off one side, and ended up using a flat screwdriver with some duct tape over the end to carefully ease the plug wire out...it's quite deep. But listen, if I can do it, ANYONE can do it.
Kerry in Mpls
...busted the little plastic lip off one side...
Me too. :( In my case, there is still enough for the Parnes tool to grab onto, but I wish I had aligned it more carefully.
I broke the plug wire slotted portion prying it out. Now I just take off the valve cover since I adjust the valves at the same time I change the plugs.
Forgive me for asking but where exactly is the second plug. I believe it is located on the bottom of the cylinder and requires removal of the fairing.If I am wrong please help.
On the RT, you do have to remove the tupperware to get at the second plug. On the GSs, you have access. I used an extra extension and "pinned" it on the socket so it wouldn't come off inside the spark plug hole. I guess you might call that a special tool.
Dick_at_Lake_Tahoe_NV
It's a good idea to carefully release the tab securing the ignition coil wiring connectors and disconnect the connnectors before you pull the coil out. This goes for top and bottom plugs.
On the RT, it can be done without completely removing the tupperware. If you remove the lower screws, the plastic is flexible enoigh that you can get to the secondary plugs.
With my R1100RT, I bought not one but two of the plastic tools to pull the plug wires (duplicate order when I was buying off my parts list), but rarely used either. I just used two pair of needle-nose pliers crossed, to gently work the plugs out. Then I put Nology wires on the bike which lacked any kind of tab on the end to use with the puller, and never used the special tool again. I assume my R1200RT uses the same tool, and assume I now have 3 of them which I'll probably never use. :/
I'll pick up the wrench from Harbor Freight next time I'm there. I have the BMW plug wrench, but would rather use a torque wrench than rely on my finely-honed mechanical sense of touch to strip the heck out of plug threads of my new RT's heads.
Why is this important?
Because that little wire can break quite easily and is probably a million bucks to replace. I unplug it first, then use a pair of flat head screwdrivers to pop the coil loose myself. The little plastic tool is crap, and I'm to cheap to buy the metal one when it only takes a light pry and out the coils come. As far as the socket I just use a regular Craftsman deepwell metric socket. Putting them in does give me an excuse to use my new Snapon techangle torque wrench... God I love trick tools....
I have a "dedicated" spark plug socket: A cheap plug socket, turned on a lathe to a smaller diameter, with an extra extension permanently attached via JB Weld.
Also, if the connector is still in place it can be partially separated when the coil is pulled. I did this while changing my plugs and the result was a serious "miss" under heavy throttle use after the plug change. Took a little while to find but the connector had pulled apart slightly.
