Rt4Me Posted August 10, 2005 Share Posted August 10, 2005 Need help finding the Mcmaster carr part numbers for the fuel filter line clamps and the vent hoses. Will be replacing fuel filters at my tech day and want to have them on hand. I know there are 2 sizes and someone has posted the mcmaster carr part numbers but I cannot find them. Thanks in advance. Bill Link to comment
Londoncallin Posted August 10, 2005 Share Posted August 10, 2005 If you want to replace the vent line ones with FI S/S screw type clamps the only ones I found that would fit were from McMaster-Carr, part# 53175 K23, if you replace the fuel filter the clamps are larger, part# 53175 K27. Link to comment
tomk99r11 Posted August 11, 2005 Share Posted August 11, 2005 Many here use the standard worm screw type clamp. I bought stainless FI clamps to fit 5/8 in. FI hose, at NAPA for 69 cents each. Nothing magical about McM clamps. FWIW. Link to comment
Jim VonBaden Posted August 11, 2005 Share Posted August 11, 2005 Many here use the standard worm screw type clamp. I bought stainless FI clamps to fit 5/8 in. FI hose, at NAPA for 69 cents each. Nothing magical about McM clamps. FWIW. I wouldn't ever use a worm style clamp on a 40PSI FI hose. That will almost certainly fail. You can get FI screw clamps at almost any autoparts store. SS ones are recommended for In-tank applications, but not absolutely necessary. Jim Link to comment
Clive Liddell Posted August 11, 2005 Share Posted August 11, 2005 You could get the real mccoy from your friendly dealer for around ~$1 (not sure of my conversion) Link to comment
calrider Posted August 13, 2005 Share Posted August 13, 2005 Bill I have some of both sizes from McMC... I'll bring them on the 28th... Link to comment
Rt4Me Posted August 13, 2005 Author Share Posted August 13, 2005 Thanks, I just found the numbers and ordered more for the tech daze. Bill Link to comment
Cali Kid Posted August 14, 2005 Share Posted August 14, 2005 I wouldn't ever use a worm style clamp on a 40PSI FI hose. That will almost certainly fail All due respect, it aint so. I have been running screw type clamps for 31.5K. Last filter I replaced, the hoses looked just dandy. In fact they were stuck in place so i know they haven't been sliding under pressure. Nothing against FI clamps, but I don't see the need for them or the time spent on ordering when there are readily available and viable alternatives. To each his own. I'll eat my words if I ever end up stranded somewhere. Till then...fooeey Link to comment
