2 screws left over-?
Dans08
I removed the body work it install Centech and adjust the valves and do a TBS. The bike has the stainless steel screws for the body work.
I have the bike back together agaqin and I found I have two black screws left over which are identical to the SS screws and I don't know where they belong. Any ideas?
Silver Surfer/AKAButters
Let's see,
1 ea. under the mirrors.
1 ea. either side of the front air intake
2 each side in front of and above cylinder heads
Front of seat behind gas tank
The ones under the mirrors are the really long ones.
I always forget the ones at the oil cooler, under the headlight. I also forget the ones by the cylinder heads, but there are four of them.
Oh, and above the license plate. :dopeslap:
Truth be told, I hate those things. :P Almost enough to make me trade for an R or a GS.....
It may be best to take all the body work back off and start over. Seriously though slowly follow the body work around in a circle until you find the empty holes, the only hidden screws are under the mirrors and at the rear of the gas tank, the last two will be obvious if you remove the seat. As previously stated check by the oil cooler and around the cylinder head. Remember it will not be fair if you don"t let us know where they belonged.
What has me stumped is, where do these belong.
Before I started removing the body work screws I made a cardboard template by this I mean, I draw the shape of the body panels on a piece of cardboard for each side of the bike. I punched a hole in the cardboard in the location for each screw and as I removed the SS screws I inserted the screw into each hole in the template this way I knew where the screws belonged when it was time to re-install the panels.
These 2 black screws where placed in a cup and now I don't remember where they belong. Fun!
I think I'll have to do that and I'll post an update.
They were the ones you found that fell out when you removed the seat that was left there by the original owner when he changed out all the black screws for the stainless ones :grin:
right in front of the seat....
I thought I looked there but I'll look again.
I seem to remember these screws were covered by something and thats why they were not SS.
I'll look this thing over until I find where they go. There is still snow on the ground so I have time.
I created this thingy to keep track of my fasteners. As you can see, I have four extras too.
Cribbage anyone!
Thats just about what I did but with cardboard. I like the wood idea, I may have to copy it. :)
I have six in the center not counting the two covered by the seat. Also check the two that go in the corner of the speakers.
Bingo - I forgot about the ones by the speakers. Yes! Thanks
