Shifting gears without clutching
jojo
I started practicing gear changing without clutching a while ago and i can now shift gear up and down rather smoothly. My question is:
Is there a risk of damaging the transmission or any other elements in doing so?
I had to replace the clutch disk of my 1150rt after 22k mls and wouldn't like to go through that job again. Still, I'd rather change a clutch than the gearbox....
Silver Surfer/AKAButters
I guess it depends on how smooth you are. Any unecessary jostling of the innards is something to be avoided IMO.
George, there is always a risk unless you ALWAYS exactly match engine RPM to proper trans RPM.. The closer you get the speeds matched the less chance of damage..
Even when done correctly it is mostly done on the up-shift not the down-shift..
The actual shifting-sleeve dogs in trans are not all that robust & the engagements ears can round off easily so keep that in mind if you keep shifting without the clutch.. Trans work on a BMW motorcycle is expensive & not sure you will get warranty coverage if the shift dogs are all rounded off..
Might be wise to at least use a little clutch disengagement during the shift..
Twisty
I, too frequently shift up without using the clutch, most often in the upper gears (5th to 6th and 4th to 5th). It's easy, and, if done carefully, doesn't damage the trans dogs.
But, your experience with a worn clutch on the R1150RT is not unusual. These clutches are prone to wear if used hard (the California Hwy Patrol goes through these frwquently, as the guys ride hard).
Key is to avoid slipping the clutch whenever posible. Avoid fast starts, long slip times (uphill, or with high loads, etc.).
Clutch disc smell is a warning of hard use.
My R1100Rt chutch is fine at 186,000 miles, as I always try to be easy on it.
Also, be sure to adjust the cable to give the right amount of ferr play (not an issue on newer hydraulic clutches).
I've posted the question before, and after some discussion, decided that it's best to use (at least some) clutch on the RT since the gear spacing is fairly wide.
I rarely use the clutch, up or down, on the gsxr. And the transmission and clutch are fine, after 61,000 miles.
Deadboy, you obviously didn't have to replace your clutch after 20k mls!! I did :(...Probably because I use the bike a lot for city commuting and also I used to downshift to slow down the bike (without bleeping the throttle).
The dry mono-disk clutch installed the R series tends to wear very quickly if you slip the clutch plates too hard.
I commuted for years in city traffic (not currently thank god) on a variety of bikes and never once felt the need to do this. Mind you I know plenty of folks who do it on their bike and in their car even but I just do not see any reason or advantage to it and plenty of downside or potential for costly damage.
Why.....what benefit is their to not using the clutch?
1. Smoother, if done correctly.
2. Easier shifting at a high lean angle.
So like when Rossi is trying to slide by you in a corner?
Yep. Your shifting hand can get in an awkward position when you're hanging off the bike, especially on left turns.
Survived-til-now
My advanced riding instructor was quite keen on clutchless up-changes and made me practice them on my 1150RT. Quite useful for very rapid acceleration through the gears....
Shortly after this "training" my gearbox went :cry:
So I keep clutchless changes for just those occasions when I want to get out of trouble quick.
