decorbin Posted August 10, 2005 Share Posted August 10, 2005 Has anyone found a good antenna mount for the RT yet? I designed my own for previous bikes (two RT's, K12RS, and three RR's) but don't really see anything that looks too promising at this point. Right now, I have my no ground plane required GMRS antenna attached to the topcase with dual lock. Works fine with that short antenna, but I would like to switch to an amateur antenna from time to time. Has anyone seen a good mount yet? An R12RTP perhaps? Thanks. Link to comment
CraCol Posted August 10, 2005 Share Posted August 10, 2005 Right now, I have my no ground plane required GMRS antenna attached to the topcase with dual lock. Can you tell me more (or shoot me a link) about the non-ground plane GMRS antenna your using? I'm using an Audiovox handheld GMRS and the range leaves a bit to be desired. Top box is probably the easiest.. I've looked at the LT atenna mounts, but haven't gotten a hold of one to see how they could be mounted back by the rack. Craig Link to comment
decorbin Posted August 10, 2005 Author Share Posted August 10, 2005 I buy a lot of antennaes from www.antennex.com. If you have a good ground plane, the TRAB4503 is a slick antenna. If not, use the B4502N. You can buy the necessary coax and some mounts from them too. Depending on where you are, they may have a dealer in your area. I generally order direct and probably pay more than I would if I could find someone who carries their products. Link to comment
