Dan B. Posted January 6, 2009 Share Posted January 6, 2009 Hello, I currently have a Garmin 550 Zumo on my R1200RT. I am wanting to purchase an Autocom unit and I have a good Idea of what connections I will need to interface the Garmin with the Autocom, However I would like to get an opinion on what lead I would need to connect the top 2.5mm output port on the garmin docking unit to the Autocom so I can speak back to the caller when my garmin has bluetoothed to my cell phone. I understand there is a dedicated bluetooth unit offered by Autocom, howevr I was hoping to do a hardwire setup instead to save money. Any help would be appreciated. Thanks, Dan B. Link to comment
JimD Posted January 6, 2009 Share Posted January 6, 2009 I have my autocom hooked up to my 550 via the autocom furnished cable. I am able to understand the people that call me, but they have a real problem understanding me. I completly replaced the autocom unit & cable under warranty once, but the problem did not change. I ride a 2007 R1200RT & just use the hookup to know when someone calls me. Then I decide when I need to return the call when I stop. Link to comment
John Bentall Posted January 6, 2009 Share Posted January 6, 2009 You have 2 primary choices 1) Get a current Autocom 200 or 300 unit in the half-price sale and use the bluetooth part #1273 plus part $1314 or 2) Wait for the 2009 Super Pro Auto and use the hardwite cable #1299 (which is just about to have its number changed to #2190!) No doubt others will come up with some more options. Link to comment
MickFinn Posted January 6, 2009 Share Posted January 6, 2009 I use a Pro7 Autocom on my 05 RT and have it linked to my Zumo 550 with two Autocom provided leads. I have my phone paired with the Zumo and even today was able to receive and answer calls while driving around the legal limit! I initially was going to use the Autocom bluetooth system but the dealer supplied two audio leads at a fraction of the cost of the bluetooth set up. I cannot remember the part numbers but if you search the Autocom site you will find leads which give you a variety of options. My set up allows mp3 playback and phone use. It mutes and pauses mp3 player when I get an incomong call. I've been using this setup for two years on my RT without any problems. Link to comment
allikanbe Posted January 6, 2009 Share Posted January 6, 2009 If you haven't already, check the www.zumoforums.com site for tons of info. Link to comment
Limecreek Posted January 7, 2009 Share Posted January 7, 2009 Check out this option from Edsets. Scroll to the bottom. All you need is a set of earbuds and you are in business. Link to comment
Dan B. Posted January 7, 2009 Author Share Posted January 7, 2009 John, why won't the hardwire version work on the current autocom unit for input into the Zumo. I thought that was what the 2.5mm port was for on the Zumo ??? Dan.. Link to comment
