DougD Posted December 27, 2008 Share Posted December 27, 2008 Any pics or tips that lends to a neat installation of an Autocom Super Pro AVi into a tankbag? I plan on putting my Kenwood 2way radio and cell phone in there also. The tankbag is a Wolfman Explorer. Link to comment
Bud Posted December 27, 2008 Share Posted December 27, 2008 I do it, but it's not neat. Just throw it all in and cuss every time I try to get it all untangled and out of there. Link to comment
randy Posted December 28, 2008 Share Posted December 28, 2008 i have had one for 7 years now. I use a medium size big mack bag. I will take some pics in simple terms I have a centech fuse panel and autocom unit. I power the autocom and GPS off this centech. I use batteries for my kenwood GMRS radio. I can have the radio, autocom wallet, and phone in there. but that is about all. Link to comment
EffBee Posted December 28, 2008 Share Posted December 28, 2008 I installed one inside of a flip-up, easy-to-remove Big Mak Tank Bag and still have the tank bag and Autocom operating like a dream. The difference is that I didn't install a Pro Rider, but an Active Rider. Here's a link to the story I wrote (with pictures) for this board when I completed the project. Link to comment
DougD Posted December 28, 2008 Author Share Posted December 28, 2008 I plan on using the tankbag on both of my bikes. So, the Autocom and Kenwood will be permanently installed in the tankbag. My GPS is externally mounted and will connect to the Autocom via the cable from Autocom. I'm also using a Powerlet part to power the tankbag. Link to comment
Mr_Ed Posted December 28, 2008 Share Posted December 28, 2008 I cut a piece of PVC board to match the bottom of my tank bag. I then laid out all the components on that to determine what worked best given that the orientation of certain items drove requirements with wires going one way or the other.... Once I determined the best position I drilled holes in the PVC board so that I could zip tie each piece/component directly to the board.. laid it down in the bag after that...works well enough and nothing slides around. Link to comment
Dans08 Posted December 28, 2008 Share Posted December 28, 2008 I've been wanting to do something like this too. Does the tank bag scratch up the tank? Is it easy to put gas in the tank with the bag in place? How do you deter thieft? Link to comment
Mr_Ed Posted December 28, 2008 Share Posted December 28, 2008 I've been wanting to do something like this too. Does the tank bag scratch up the tank? Is it easy to put gas in the tank with the bag in place? How do you deter thieft? I use a BigMak tankbag http://www.cyclegadgets.com/Products/BigMak/ ..... No issues with the design of a bigmak scratching the tank AND since it's on a hinge I just flip it up and forward to gas up. When the bike is parked I simply push the helmet lead into the bag so it's not obvious that there's anything in there more than a map. A simple strip of velcro keeps the bag secured on the platen and the wire for power is easily detached so to pull the bag off and lock it in a side bag is all that's needed to keep it safe when it's in a public space for more than an hour or two. Link to comment
thencamebronson Posted December 30, 2008 Share Posted December 30, 2008 Big Mak seems to be the way to go. I am on my third iteration of tank bag/autocom/audio and think I finally have it sorted. The BigMak bag works well because it has velcro on the inside of the bag to attach the items to, unless your handier than me and can make something like EffBee did, and it also has a flap on the bottom for wires and cables. Anyway, first version for me was on an LT I had for a while and used the BMW LT tank bag, there isn't a lot of room in there and no holes for cables. Second try was on my RS with a Big Mak bag. I took a plastic cutting board from WalMart and cut a piece to stand up in the bag using velcro. I attached my autocomm (I cant remember the model, but it is small) and a three outlet 12V receptacle. I also used an amplirider mixer and plugged it all into a BMW access outlet wired direct to the battery with an inline 15 amp fuse and a powerlet tankbag connection. Good but not great. The amplirider picked up a buzz from my ipod charger and the XM plug in. Worse on the XM. Too many wires and took up too much tank bag space. Current setup uses a BMW tank bag electrification kit for power and I have the autocomm velcroed in the bag. I spliced the power for the autocomm into the BMW "tbek" wire and use the switched 12v outlet that is part of the "tbek" to charge ipod or cell phone. I use an ijet remote for the ipod and the leads for the autocomm are fed out of the hole in the bottom of the tank bag. I use the autocomm part that allows you to plug in earphones. I'll try to remember and get some pics. I am thinking of adding a mix-it to my setup since my autocomm only has one audio input and I am using a gps now, along with either XM or ipod. Link to comment
Albert Posted December 30, 2008 Share Posted December 30, 2008 I do it, but it's not neat. Just throw it all in and cuss every time I try to get it all untangled and out of there. Copycat. Link to comment
tallman Posted December 30, 2008 Share Posted December 30, 2008 Do the Big Mak. I've used the Diamond Space Case (smallest, designed to mount on top of other bags) by itself for years. Flip to fill, clear map case to see cell phone so I can be a distracted driver too. My XM radio puck and an aadditional external GPS antenna all sit in the mapcase window, along w/garage door opener, and there's still space to slip a map or printout into. Locking TouraTech GPS mount allows short term safety, and the whole setup can be removed in about 10 seconds and locked in a hard bag. Link to comment
SageRider Posted December 31, 2008 Share Posted December 31, 2008 I picked a Marsee 10L Tear Drop tank bag with the strap mount. I then replaced the strap mount (which zips to the bag) with a SW-Motech/Bags Connection powered fuel filler ring mount. I'm running Autocom Pro-7 Sport, Garmin 376C + GXM-30, Valentine V1, Verizon Wireless XV6800, and a Yaesu VX-5 Link to comment
Foot Posted December 31, 2008 Share Posted December 31, 2008 Micheal I just bought that tank bag. How did you attach the mount for the GPS? Alan Link to comment
SageRider Posted December 31, 2008 Share Posted December 31, 2008 There is a "TechMount" available for the hard top bags which consists of a cross rail with 3 mount points and a single mount. One mount was used for the GPS, and I acquired an additional mount for the V1. Each mount includes the top and bottom pivots, the bar, and the mounting plate. The mounts can be mounted on the bar in 45 degree increments (See GPS mount location). The only weakness of this mount system is that there is not a ball socket to increase plate angle flexibility. If GPS mount plate was horizontal instead of vertical, it would be angled at 45 degrees same as the mount. To complete the GPS mount, I partially dismantled the Garmin marine mount which was included with my Garmin unit when purchased. Bolted the Garmin piece right to the TechMount plate with no additional modification needed. Link to comment
Dans08 Posted January 1, 2009 Share Posted January 1, 2009 Alright, you guys gave me something to work with, there are some great ideas here. Thanks. Link to comment
