bobbobtar Posted December 25, 2008 Share Posted December 25, 2008 Are the crush washers the same for the engine oil drain plug,transmission drain and fill plugs,final drive drain plug. Thanks. Link to comment
T__ Posted December 25, 2008 Share Posted December 25, 2008 Bob, nope,, you can look them all up here to see what ones are the same though.. Clicky_this_Linky Twisty Link to comment
bobbobtar Posted December 25, 2008 Author Share Posted December 25, 2008 Twisty, I can always count on you for right answer,should of thought of Max. Thanks. Link to comment
Horizons Posted December 25, 2008 Share Posted December 25, 2008 Here are some numbers from an oilhead. I believe your engine drain sealing ring is the same. 07-11-9-963-200, 14 x 18 x 1.5 mm (final drive fill and drain), 07-11-9-963-252, 16 x 20 x 1.5 mm (engine drain), 07-11-9-963-300, 18 x 22 x 1.5 mm (transmission fill and drain). All of the above are natural aluminium sealing rings, DIN 7603A. Link to comment
