Mr. Frank Posted December 21, 2008 Share Posted December 21, 2008 Some time ago someone posted instructions for the left side cam chain tensioner upgrade with pictures. Can someone direct me to it? Link to comment
ESokoloff Posted December 21, 2008 Share Posted December 21, 2008 How about this, this, and this? I remember someone claiming they had a procedure that did not require disconnecting the throttle body but I cant find it. Link to comment
knight88 Posted December 21, 2008 Share Posted December 21, 2008 I remember someone claiming they had a procedure that did not require disconnecting the throttle body but I cant find it. I just used a socket with a universal joint and I didn't have to remove anything at all, it fit in tight but it worked. Link to comment
jm1515 Posted December 21, 2008 Share Posted December 21, 2008 I remember someone claiming they had a procedure that did not require disconnecting the throttle body but I cant find it. I just used a socket with a universal joint and I didn't have to remove anything at all, it fit in tight but it worked. I needed to use 2 U-joints and a shorty extension to angle behind the strut but it was easy. Was even able to get a torque wrench in there after removing the left oil cooler cover on my Roadster.... Link to comment
moshe_levy Posted December 21, 2008 Share Posted December 21, 2008 All- I have completed an updated procedure for this and it's coming out in the March edition of Motorcycle Consumer News. I believe the procedure I outlined (learned from Tom Cutter) is simpler (less chance for error) and less expensive than these older threads illustrate. -MKL Link to comment
DGShaffer Posted December 21, 2008 Share Posted December 21, 2008 Perry and I have ours waiting for installation. I can't wait for your article Moshe! Link to comment
moshe_levy Posted December 21, 2008 Share Posted December 21, 2008 We should have an installation party! My garage is yours on "my" weekends. Here's a picture of the upgrade kit. The installation procedure I outline as Cutter instructed will save time, effort, and money over the older threads on this subject. -MKL Link to comment
DGShaffer Posted December 21, 2008 Share Posted December 21, 2008 That's the one! I actually bought two from Tom. Link to comment
SAAB93driver Posted December 22, 2008 Share Posted December 22, 2008 Some time ago someone posted instructions for the left side cam chain tensioner upgrade with pictures. Can someone direct me to it? http://advwisdom.hogranch.com/Wisdom/CamChainTensionerSwap.html Link to comment
Mark G Posted December 21, 2010 Share Posted December 21, 2010 http://www.ebbo.org/stop_the_rattle.php Link to comment
