lexxol Posted December 19, 2008 Share Posted December 19, 2008 Is the transmission drain plug on a 04 1150 RT magnetic? Thank you Link to comment
NumbHands Posted December 20, 2008 Share Posted December 20, 2008 Go see if it wants to stick to the refrigerator door. Link to comment
lexxol Posted December 20, 2008 Author Share Posted December 20, 2008 Your a rocket scientist right. Link to comment
lexxol Posted December 20, 2008 Author Share Posted December 20, 2008 I have found the answer. Thank you Link to comment
Stan Walker Posted December 20, 2008 Share Posted December 20, 2008 I have found the answer. Thank you Did you check both drain plugs? There is a big drain on the bottom of the transmission. You have to remove the cat can to get to it. Stan Link to comment
Mark K Posted December 21, 2008 Share Posted December 21, 2008 Go see if it wants to stick to the refrigerator door. .........depends on what kind of fridge he has....... Link to comment
waylap Posted December 22, 2008 Share Posted December 22, 2008 Poor fella. You guys are brutal. Link to comment
effexer1 Posted December 23, 2008 Share Posted December 23, 2008 If your plug sticks to one of those Stainless Steel fridges, the plug has too much crud on it..... or your young fellow got jam on the door.... Link to comment
T__ Posted December 23, 2008 Share Posted December 23, 2008 Steve, Just because it is stainless steel doesn’t necessarily mean it is non magnetic.. A lot of the 400 series stainless steel is magnetic as well as the 304 series if it is cold rolled or excessively worked.. The more nickel it contains the less likely it will be magnetic.. Twisty Link to comment
