bobsden Posted December 16, 2008 Share Posted December 16, 2008 Has anyone got a lift for the R1200RT that they can recommend? Link to comment
Tony_K Posted December 16, 2008 Share Posted December 16, 2008 You might want to clarifiy you are in the UK in your post header. You will save yourself from a lot of US responses. Link to comment
T__ Posted December 16, 2008 Share Posted December 16, 2008 Has anyone got a lift for the R1200RT that they can recommend? Bob, I am extremely happy with the Handy lift.. It is a very heavy duty lift table with a good air lift cylinder.. A lot of motorcycle repair shops over here use the Handy lift.. Problem is it is quite heavy & shipping would be high to your country unless they have an outlet over there.. Because of the size & shipping weight you probably need to look closer to home & at what people in your area are using.. Twisty Link to comment
ogjimbob Posted December 17, 2008 Share Posted December 17, 2008 You might want to clarifiy you are in the UK in your post header. You will save yourself from a lot of US responses. I thought the England in his details did the job makro had a deal on hydraulic lifts with a capacity of 400kg, a couple of weeks ago, about £40 might be worth a look, although you might wish to check if you can lift an RT in that manner. Link to comment
Tony_K Posted December 17, 2008 Share Posted December 17, 2008 I thought the England in his details did the job You would think so wouldn't you... on BMWST details are often over looked or just outright ignored. Link to comment
