EddyQ Posted December 7, 2008 Share Posted December 7, 2008 Just replaced my low beam with a Sylvania/Osram standard H7 after the original bulb blew in only 7Kmi. Based on the numbers on the original bulb, it is a Osram 64210 or exactly the same as the sylvania standard. So, I won't likely get much more life with this new bulb. Has anyone got experience with a Philips Motovision or ExtraDuty bulbs?? They cost 4-5x the sylvania standard, but are worth it if they last 4x longer. They claim to last much longer in vibration uses. So how long on a 2007 RT? Perhaps an RT kills bulbs with voltage, then it won't matter if it is a $20 bulb or $5 bulb. Also, where do you buy these Philips ExtraDuty bulbs?? Link to comment
