dharnie Posted December 2, 2008 Share Posted December 2, 2008 I have a "bad Boy"/"stebel" air horn in the front upper fairing on my Yamaha Venture. Can this fit somewhere hidden on the 2004 1150RT? Anyone know? Link to comment
SinNH Posted December 2, 2008 Share Posted December 2, 2008 I mounted one on my R1100RT with a homemade "L" bracket to mount on the same stud as the stock horn,it clears each tube by about 10mm. Steve Link to comment
moshe_levy Posted December 2, 2008 Share Posted December 2, 2008 I have a "bad Boy"/"stebel" air horn in the front upper fairing on my Yamaha Venture. Can this fit somewhere hidden on the 2004 1150RT? Anyone know? TWO can fit. See my installation here http://www.mklsportster.com/r1150rthorn.htm Just cover your ears before testing them! -MKL Link to comment
Unhofliche_Gesundheit Posted December 2, 2008 Share Posted December 2, 2008 Hi Moshe - looking at your installation at the link you provided- i liked this " You will jump out of your skin at the shear volume of two air horns screaming in parallel, which sounds very much like a semi-truck’s horn on steroids!" and this " At 50 feet, the RT's horn performance went from roughly the volume of a canister vacuum cleaner (~80 dB) in stock form to roughly the volume of front row at a rock concert (~110 dB) " Awesome! looking at your photo titled "The left and right side Stebels mounted in the stock Bosch horn locations, directly behind the oil cooler. (1/07)" QUESTION PLEASE: did you pull apart the airhorn and connect 2 halves with a hose or is that how the unit comes from the factory? thx. Link to comment
moshe_levy Posted December 3, 2008 Share Posted December 3, 2008 That's how they come from the factory. Nothing whatsoever was modified, except for adding the diodes to the relays. -MKL Link to comment
snod Posted December 3, 2008 Share Posted December 3, 2008 I have the AeroStitch Ear Cannon mounted between the forks of my 97 RT. I just used a flat piece of aluminum strap to mount it to the stock mounting bolt. Sits in between the forks, with about an inch clearance on each side. I tried running it from the stock relay and wires, but the compressor just didn't have enough umph to get the low tone going full song. I used the relay that AeroStitch included with the horn and ran a wire to the battery. Works great. Link to comment
