Guy08 Posted November 25, 2008 Share Posted November 25, 2008 To change the subject I have a problem and I am new to BMW too I have 2001 R1150RT and it wont start. I turn key all lights up along with blinking red light Brake Failure. What do I do please, help Guy Link to comment
11101110 Posted November 25, 2008 Share Posted November 25, 2008 Well if the kick stand is up you could try it in Neutral. If it starts in N then you probably have a bad kickstand switch. But on my 02 the engine will crank with the kickstand down and clutch open, just won't start. Won't even crank with the clutch closed. Not sure if you have to open the clutch to strat it in N though. The three position kill switch is in the middle position right? Link to comment
AndyS Posted November 25, 2008 Share Posted November 25, 2008 ... I have 2001 R1150RT and it wont start. I turn key all lights up along with blinking red light Brake Failure. What do I do please, help Guy Is the kill switch on the right hand switch cluster turned and disabling the engine. When you push the starter button, does the engine rotate or not? Andy. Link to comment
BigAL Posted November 26, 2008 Share Posted November 26, 2008 NEED MORE INFORMATION.......... Link to comment
