Stephen_Chase Posted November 14, 2008 Share Posted November 14, 2008 Can anyone advise if I need a Canbus charger for my 2005 K1200S? Thanks, Stephen Link to comment
Satguy Posted November 15, 2008 Share Posted November 15, 2008 Yes, you will need a "Canbus" charger if you want to charge your battery throught the controlled acessory socket. On the other hand, you can connect virtually any trickle charger directly to the battery. Just remove the small battery cover directly behind the handle bars to gain access to the battery. Winter there in the east yet? Link to comment
stubble! Posted November 19, 2008 Share Posted November 19, 2008 I use the latter method. A battery tender junior. I don't even remove the cover, instead I have an SAE connector pigtail wired to the battery, sticking out of the cover a couple of inches. Normally my tank bag plugs into the connector. Link to comment
Stephen_Chase Posted November 20, 2008 Author Share Posted November 20, 2008 Hi Bruce, Thanks for your quick reply. Cool but winter is not here yet, like London. I get regular reports from my son at Western. Cheers! Stephen Link to comment
