abs rearm
chasgrips45
Yes I understsnd that. However there is a certain sequence one must follow to rearm the ABS computer. One has to gruond 2 special terminals at the circuit board & Press the ABS rearm button for a certain # of seconds, I can`t remember the sequence. At 63 I have a condition called CRS ( can`t remember sh-t)
Danny caddyshack Noonan
Resetting ABS1, assuming you have abs 1....
* Locate the diagnostic connector on the right frame rail, under the seat. Remove it from the blanking plug.
* Insert one end of 20 cm wire into the middle socket of this connector.
* Ground the other end firmly to a metal bolt in the area (and keep grounded).
* Hold the ABS button down as you turn the ignition on. You should see the lights flash together as normal.
* Keep holding the ABS button down for about 8 seconds. The ABS light will stay on solid.
* Release the ABS button.
* Turn off ignition, remove wire.
