Rear brake pad inspection hole #1
Bob Atkinson
When you remove the right side bag to look at the inspection hole #1 per owners manual which hole is #1? Front or rear? The manual is not clear to me. Anyone know the min. pad thicknest allowed?
Thanks
Minimum front pad thickness 1.0 (0.039) mm (in)
Minimum rear pad thickness 1.0 (0.039) (wear mark) mm (in)
That's from the BMW Repair Manual for an 1150 RT.
