Vicious_Cycler Posted November 2, 2008 Share Posted November 2, 2008 For some time I have lusted after the Marsee Mr. Pockets 20l Corona-mount tankbag. After my Tank Locker died, I lucked up on a NIB Marsee on Ebay for roughly half-price and dream fulfilled! However, as with many dream relationships... The bars contact the side pockets in lock to lock positions. Not so bad to the right, but left lock contacts the horn button causing an immediate state of alarm, disconcertion, and embarassment. I also find myself not turning to lock when U-turning or foot-manuvering the bike while astride. Of course, knowing how far I can turn the bars without blowing the horn is a exercise above my level of precision. Thus, I am driven to distraction when moving around at parking lot speeds. I am hopeful of creative remedy suggestions from the great minds here on the board. For starters I have considered: 1) removing the offending pocket 2) moving the Corona ring to my old tankbag 3) rigging a cut-off switch for the horn used during above manuvering I would really like to know what others think as a possible solution. Thanks! Link to comment
effexer1 Posted November 2, 2008 Share Posted November 2, 2008 My Big Mac pushes the windshield down button at left lock, and after a parking lot maneuver I have to reset it. It is disconcerting, but no on knows but me! Link to comment
SageRider Posted November 2, 2008 Share Posted November 2, 2008 You mean you can actually hear the horn??? Actually, I would try to construct a shield around the horn button.... Still easy to press with a gloved finger, but blocked from a large relatively flat object like the tank bag. Link to comment
Vicious_Cycler Posted November 2, 2008 Author Share Posted November 2, 2008 The horn is an upgrade. Maybe I should put the original back on. A sheild, brilliant!, super glued maybe? Link to comment
allikanbe Posted November 2, 2008 Share Posted November 2, 2008 small piece of velcro on the insides of the pocket to keep that part of the pocket that hits the horn narrow and still use the rest of the pocket Link to comment
SageRider Posted November 2, 2008 Share Posted November 2, 2008 The horn is an upgrade. Maybe I should put the original back on. A sheild, brilliant!, super glued maybe? Superglue, Velcro, or small screw.... Link to comment
waylap Posted November 2, 2008 Share Posted November 2, 2008 Here;s exactly what you need; made by Wunderlich for $24 and protects the horn button. It's made just for that problem. http://www.bmwsantacruz.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=8500247&Category_Code=R1150RT-X&Product_Count=13 Link to comment
Vicious_Cycler Posted November 3, 2008 Author Share Posted November 3, 2008 That's it! I knew someone would have a solution. Thanks. Link to comment
jwg122843 Posted November 3, 2008 Share Posted November 3, 2008 I have the Marsee 20 liter soft bag and really like it. But the straps are a PITA at each fuel stop.So I am working on a solution that would work on any tank bag.I am machining an aluminum ring that will screw to the top of the tank with longer screws. The ring will have a pattern of "keyholes" and there will be a plastic piece with twist-in keyholes that will allow the tank bag to be snapped in or off in a matter of seconds. This plastic part will be either riveted or attached to the tank bag base with grommets and my misery will be over. Link to comment
