Michaelr11 Posted October 28, 2008 Share Posted October 28, 2008 Can a gearbox from an '02 R1150RT be used to replace the gearbox in an '01 R1100RT? Output/Clutch splines failed; there's an 1150 gearbox available. Michael Link to comment
ogjimbob Posted October 28, 2008 Share Posted October 28, 2008 Can a gearbox from an '02 R1150RT be used to replace the gearbox in an '01 R1100RT? Output/Clutch splines failed; there's an 1150 gearbox available. Michael I think the mountings are different, but I'm sure someone will come along shortly who knows for sure Link to comment
Ken H. Posted October 29, 2008 Share Posted October 29, 2008 While anything is in theory possible, for all practical purposes, this is not. It’s not so much the tranny bolting up to the engine, it’s all the other issues: Clutch has to change (the splines are different), the rear swing arm mounts different, cable vs. hydraulic clutch mechanism, the rear sub-frame mount points are different, and more. Link to comment
guitardad Posted October 29, 2008 Share Posted October 29, 2008 While anything is in theory possible, for all practical purposes, this is not. It’s not so much the tranny bolting up to the engine, it’s all the other issues: Clutch has to change (the splines are different), the rear swing arm mounts different, cable vs. hydraulic clutch mechanism, the rear sub-frame mount points are different, and more. There are more details here, but Ken has the essentials. It's really not feasible. Link to comment
