luvnitro02 Posted October 25, 2008 Share Posted October 25, 2008 08 1200 rt looking for procedure with specs for adjusting the rockershaft eng play. what the clearence should be and torque specs for bolts. Making my first attempt at valve adjustment. have the valve specs but saw the information at one time on here. thanks Mike Link to comment
Firefight911 Posted October 25, 2008 Share Posted October 25, 2008 Here's a great end play post - LINKY Link to comment
luvnitro02 Posted October 25, 2008 Author Share Posted October 25, 2008 Thank you very much. Is the headbolt torque 20nm then 180 degrees? Link to comment
T__ Posted October 25, 2008 Share Posted October 25, 2008 08 1200 rt looking for procedure with specs for adjusting the rockershaft eng play. what the clearence should be and torque specs for bolts. Making my first attempt at valve adjustment. have the valve specs but saw the information at one time on here. thanks Mike Mike, you have good info on the procedure I will just add a few observations.. First, I have done quite a few rocker end play settings & found that using a feeler gauge it is difficult to get them to minimum (the closer to the lower spec you get the quieter they will be) so found that using a dial indicator is (my) much preferred method as far as ease & precision goes.. Next, just a little warning.. There are some incorrect torque specifications posted in some on-line rocker end play procedures,, probably based on some incorrect DVD info from a while back.. So double check the torque info against a credible manual before proceeding as you don’t want to damage anything.. Most info is accurate but there is always a chance you are looking at the skewed info.. Twisty Link to comment
Effjay Posted October 25, 2008 Share Posted October 25, 2008 I checked mine the 1st time myself a few weeks ago at 13.5K. All was still at spec since dealer performed 6K service. I took pics as "proof" for my records (probably overkill) but I'll share if anybody worries the procedure is too tough to tackle. Jeff LH exhaust LH Intake RH Exhaust RH Intake Link to comment
jmf Posted October 25, 2008 Share Posted October 25, 2008 Now this looks like a good idea Matt First, I have done quite a few rocker end play settings & found that using a feeler gauge it is difficult to get them to minimum (the closer to the lower spec you get the quieter they will be) so found that using a dial indicator is (my) much preferred method as far as ease & precision goes.. Twisty Link to comment
