fossil Posted October 23, 2008 Share Posted October 23, 2008 This is the first for me on the RT. Is bottom plug replacement possible without removing and beating up the tupperware? Link to comment
BFish Posted October 23, 2008 Share Posted October 23, 2008 i've always removed tupperware to change out the secondary plugs.. it might be possible not to, but don't think so. Link to comment
AndyS Posted October 23, 2008 Share Posted October 23, 2008 ....Is bottom plug replacement possible without removing and beating up the tupperware? I think you need to remove the tupperware. Moreover, if you have the rocker cover protectors then you need to remove these, which definately requires the tupperware to come off. Andy Link to comment
Fugu Posted October 23, 2008 Share Posted October 23, 2008 This is the first for me on the RT. Is bottom plug replacement possible without removing and beating up the tupperware? Yes, you only need remove it, beating it up is optional and at the discretion of the owner. Link to comment
