Bologna Posted October 22, 2008 Share Posted October 22, 2008 OK gang, what is out there for replacement grips for my '02 RT? I want the grips that don't need a 100 mile break-in! Link to comment
SAAB93driver Posted October 23, 2008 Share Posted October 23, 2008 Heated. The grips covers are easy to replace. http://www.advrider.com/forums/showthread.php?t=90799&highlight=grips Finding ones other than stock that you like will be the hard part. Link to comment
knight88 Posted October 24, 2008 Share Posted October 24, 2008 I ordered two right hand BMW(throttle) grips, and just rolled the old ones off the heater element, sprayed hairspray inside the new grips, slipped them on and was done. Took all of maybe 30mins to do it. I could not find the grips mentioned in the above post. Link to comment
Bologna Posted October 24, 2008 Author Share Posted October 24, 2008 Thanks for the help, just wish we had more choices for grips. Link to comment
AndyS Posted October 24, 2008 Share Posted October 24, 2008 Thanks for the help, just wish we had more choices for grips. BMW sell them with the part number 32721458396 You will need 2 of these right hand grips because the heater barrel is the same OD on both sides I think they are about $10 each - Not sure about that last bit! Cheers Andy Link to comment
SAAB93driver Posted October 24, 2008 Share Posted October 24, 2008 I ordered two right hand BMW(throttle) grips, and just rolled the old ones off the heater element, sprayed hairspray inside the new grips, slipped them on and was done. Took all of maybe 30mins to do it. I could not find the grips mentioned in the above post. I couldn't either so buy 2 of these BMW part number 32721458396. I have read where some people have installed aftermarket grips as well, you need 2 throttle side ones so I guess you have to buy 2 sets. Link to comment
chrisz Posted October 24, 2008 Share Posted October 24, 2008 You could also just cover the original worn grips with slip on foam grips. This also gives a thicker grip which I find less fatiguing. Heating elements still work with the foam grips. Link to comment
RickB Posted October 24, 2008 Share Posted October 24, 2008 You could also just cover the original worn grips with slip on foam grips. This also gives a thicker grip which I find less fatiguing. Heating elements still work with the foam grips. +1 Love my grip puppies. 8 buck delivered. Comfy... Link to comment
Dave R1100RT Posted October 25, 2008 Share Posted October 25, 2008 2000 RT here.....I just ordered and received Dual Star heated grip elements....but have been waiting for some BMW Grips (2 rights) from Chicago BMW for ~6 weeks......I currently have foam grips....never thought about using them over the elements until chrisz mentioned it....I'll eventually install the BMW grips...but for now...it's starting to get a bit nippy in minnesota....so if the foam will work over the elements...I can run those temporarily....thanks for the idea... Link to comment
NumbHands Posted October 25, 2008 Share Posted October 25, 2008 +1 for the Grip Puppies. Heat works fine, just takes a little longer to get the gloves warm. Link to comment
