Walter Posted July 29, 2005 Share Posted July 29, 2005 OK, last one for the night. I have the radio in my RT, and the CD button cycles though CD, AUX and Intercom. Has anyone hooked up the AUX or Intercom? I'd like to, in fact, I've got an Autocom installed but would ditch it if the factory unit supports it. Thanks! Walter Link to comment
BMC Posted August 1, 2005 Share Posted August 1, 2005 With my experience with RT's they just use a similar control as the LT so you see that in the menu, I don't think it even has the ability to connect a headset. Why would you want to ditch the Autocom? Do you have the factory stereo integrated into the Autocom? Link to comment
rickcavanaugh Posted August 1, 2005 Share Posted August 1, 2005 there should be an unused 10 pin input on the back of the radio. this is the input for the AUX connection. I never did it on an RT but I have accessed it on my LT. You can build your own cable for a few bucks. The input level is very low. You will need to turn the volume way up to make it usable. try lt site Link to comment
Walter Posted August 4, 2005 Author Share Posted August 4, 2005 Would only ditch the Autocom if it was a complete duplicate. Once work slows down a little I'm going to investigate a little further. Thanks for the replies. Link to comment
