RT_Jim Posted August 3, 2008 Share Posted August 3, 2008 I've done a search of the forum but can't find anything.... I just finished my 6000 mile service and want to reset the indicator in my RID..... is there any way to do that? thanks! Jim Link to comment
Huzband Posted August 3, 2008 Share Posted August 3, 2008 Asked the service manager that question yesterday. In a word, the answer is "no". I didn't ask how much he would charge to do it for me. Link to comment
BeemerLover Posted August 3, 2008 Share Posted August 3, 2008 Put a piece of tape over the service light. You might be able to find some that matches the background. Gael Link to comment
Huzband Posted August 3, 2008 Share Posted August 3, 2008 Humor is strictly verboten on this site. Link to comment
smiller Posted August 3, 2008 Share Posted August 3, 2008 is there any way to do that? Why in the world would BMW allow a mere owner to reset the service light? Link to comment
Limecreek Posted August 3, 2008 Share Posted August 3, 2008 "Resetting the indicator: Once the maintenance work due for a given service has been completed, the mechanic uses the GT1 to reset the indicator." That is the offical word, but I am sure there must be another way. We need someone to go out and try a combination of things until they can get into the reset level and then share it with the the group. What happens if you hold the ODO reset down and turn on the key for instance? Link to comment
marcopolo Posted August 3, 2008 Share Posted August 3, 2008 Some people have suggested that the folk who manufacture the GS-911 code reader were working on an update that would allow it to be used to reset the service indicator. I have no idea whether that's true, or not, but you could always ask. Link to comment
Huzband Posted August 3, 2008 Share Posted August 3, 2008 I was wondering about the GS-911 but, not having one yet, didn't know. Hopefully an owner of such device will clue us in. Link to comment
ScottT Posted August 4, 2008 Share Posted August 4, 2008 Hopefully an owner of such device will clue us in.I have been a GS-911 owner for almost two years. It seems like it anyway. None of the software update notes mention being able to clear the service indicator. Here are the software update notes. 2008-07-10 More models, more functionality Real-time values and ABS2... Revision History for Beta version Added support for some new models: R1200S HP F800GS F650GS (2008+) F800S (added ABS and Instrument Cluster) F800ST (added ABS and Instrument Cluster) G650Xchallenge (added ABS) G650Xmoto (added ABS) G650Xcountry (added ABS) Added ABS-II (ABS2) functionality for all older 1150, K1200 and R850 models Added real-time display of Analog Input values for Engine of CAN-based bikes Added real-time values for Engine of F650GS/Dakar/CS and C1/C1-200 models Added real-time values for Engine of R850, R1150 and non-CAN 1200 models logging of real-time values to .CSV file 2008-04-24 GS-911 version 804.1: Added support for some new models: R1200CL R1200C R850C (with 10pin connector) R850R (with 10pin connector) R850RT (with 10pin connector) F800S (Engine (BMSK) & Vehicle Electronics (ZFE) only) F800ST (Engine (BMSK) & Vehicle Electronics (ZFE) only) G650Xchallenge (Engine only) G650Xmoto (Engine only) G560Xcountry (Engine only) Added realtime display of Digital Input values for BMSK (some culprits that could prevent starting): ClutchSwitch, KillSwitch, SideStandSwitches 1&2, OilPressureSwitch Tools -> Check for Updates (if you have internet access you can check whether your version is current) Help -> About : lists your specific Reseller's support contact details Some layout changes in the way models are selected 2007-05-24 GS-911 version 705.6: Bug fix on F650 twin-spark ECU (BMS C-II) that had no text descriptions for fault codes. Made the [Cancel] button the default on the fault code erase confirmation. Swapped the button positions of [Erase fault Codes] & [Copy to Clipboard] buttons Log file is now default on 2007-05-21 GS-911 version 705.4: Minor cosmetic changes from Beta 704.3 Added support for the twin-spark F650CS Changed versioning, the versioning now represents the year and month in which it was released. New Firmware upgrade build of v0.8 for the interface Added a couple of models (even non-CAN K-Series) Added Integral ABS (I-ABS) of 1150 models Added Integral ABS2-CAN (I-ABS2CAN) for 2007+ (late 2006) models Renamed ABS3-CAN to I-ABS-CAN for clarity Added ABS to several K- and R-Series models Added R1100S Several miscellaneous User Interface enhancements Added K1200, and more R1200 and R1150 Series models Parsing for New ABS controller update of 1200 series 2007-01-19 GS-911 version 1.14: Fixed a bug that showed up as "Login failed"... Fixed support for 1150 and 1200 ranges showing whether a Fault code is currently present or not Small usability issue around the "Activation information" in the Setup window. 2007-01-17 GS-911 version 1.13: Minor bugfix on usability issue. New Firmware for your interface (v0.6) 2007-01-16 GS-911 version 1.12: ABSN "Failed to get Detailed information" bug fixed BMSC & BMSC2 Status bug fixed More user-friendly grouping of controllers under the Advanced Window Defaulting to USB under Status Window Added support for C-Series Added support for F650CS Removed Bluetooth option from PC app - Bluetooth is for GS-911Mobile ;-) Various small usability issues revised Link to comment
jakfrost Posted August 4, 2008 Share Posted August 4, 2008 Speaking as the owner of 'such a device' I can say with some authority that it does. Judging by the shop rate I figure after 3 'resets' I'm break even with the cost of the GS 911. And it works with my cell phone via bluetooth! So I take it with me on the road. Jim Link to comment
Ken H. Posted August 4, 2008 Share Posted August 4, 2008 Speaking as the owner of 'such a device' I can say with some authority that it does. The "Service" indicator is new with the 2008 models, you have a 2005 correct? Which didn't have it. That being said, on the GS-911 forum (on Google) the fine folks at HexCode have said this is a feature they are working on for a future release of the GS-911 software. Link to comment
marcopolo Posted August 4, 2008 Share Posted August 4, 2008 That's what I was getting at when I said someone could ask. I meant ask the makers of the GS-911. Link to comment
Twisties Posted August 4, 2008 Share Posted August 4, 2008 What happens if you hold the ODO reset down and turn on the key for instance? Bill Gates pops up! Link to comment
GordonB Posted August 4, 2008 Share Posted August 4, 2008 I very much would like to know if the GS-911 can reset the "stepper motors" as is done at each 6000 svc at the LD. Link to comment
SageRider Posted August 4, 2008 Share Posted August 4, 2008 I very much would like to know if the GS-911 can reset the "stepper motors" as is done at each 6000 svc at the LD. Not at this time, at least on the R1200-RT. Link to comment
Jim VonBaden Posted August 4, 2008 Share Posted August 4, 2008 I very much would like to know if the GS-911 can reset the "stepper motors" as is done at each 6000 svc at the LD. Not yet, but they will figure it out. Same with the service light reset. Stephan is doing good stuff, but it takes time to reverse engineer these things. Jim Link to comment
JayW Posted August 4, 2008 Share Posted August 4, 2008 What service light are you referring to? My '05 RT either has no such thing, or it has never turned on. Addendum: Never mind - my question was answered above. Jay Link to comment
GordonB Posted August 4, 2008 Share Posted August 4, 2008 Svc lights came into being with the '08's Link to comment
jakfrost Posted August 5, 2008 Share Posted August 5, 2008 My mistake, he said 'service light', I read 'fault indication'... Geez just reading too fast these days :-) Jim Link to comment
ScottT Posted August 5, 2008 Share Posted August 5, 2008 What service light are you referring to? My '05 RT either has no such thing, or it has never turned on. That's right. Solution is to ditch the 2008 for an older RT. Old ones are faster too... especially red ones... the KGT riders are always amazed when they cannot keep up Link to comment
BeemerLover Posted August 6, 2008 Share Posted August 6, 2008 I think the '07 RT is the sweet spot. That year they took the servo brake booster off and it is before the service light. Silver has proven to be the fastest. That particular color repels photons better than all others which allows the bike to cut through photo radiation better. Gael Link to comment
Bob_Minor Posted August 6, 2008 Share Posted August 6, 2008 And if it had a FD drain plug it would be perfect. Link to comment
ScottT Posted August 6, 2008 Share Posted August 6, 2008 Silver has proven to be the fastest. Red is pretty fast too Link to comment
