Ken H. Posted July 10, 2005 Share Posted July 10, 2005 As part of repairing my 'oops', today I replaced the damaged valve cover. Much to my surprise the center spark plug hole gasket that came out definitely had dried silicon sealer on it that I had to clean off. On the R11xx this gasket was install dry. Is this a change with the hexheads? Those of you with a copy of the manual (mine is STILL on eternal backorder), what does it say about this gasket? Dry or with something applied? Thanks! Ken H. Link to comment
David_S Posted July 10, 2005 Share Posted July 10, 2005 Gaskets must be free from oil and grease, replace if damaged. Position gasket (3) on the cylinder-head cover. Position gasket (4) on the cylinder-head cover. Install the cylinder head cover, making sure that both gaskets are correctly seated. Install and tighten the screws. Tightening torques Cylinder head cover to cylinder head, tighten in diagonally opposite sequence 10 Nm Link to comment
