R1100 RT, R&R transmission, tools needed?
doc47
Posted
I've done this job before but don't have my shop manuals with me in Montana. I also don't have most of my tools. I'm having a friend ship me the tools I'll need that I don't have here, such as metric allen sockets and my torque wrenches.
Can anyone advise me on any other tools I'll need to do the job, other than the usual metric sockets, open-and-box-end wrenches, etc?
eg: are there any particularly large wrenches I'll need?
How about for replacing the clutch disc, which I plan to do while I'm in there?
I can't seem to remember anything unusual.
Also, can anyone email me the relevant pages from the Haynes Manual? I'd be much obliged....
Posted
How about I just send you the manual for the r1100rt and when you are done you send it back?
Posted
Uh, that the Haynes manual I have
Posted
Tank, that would work jes' fine. Still got my address?
Anton Largiader
Posted
Just make sure that isn't the manual that tells you to completely remove the rear subframe.
Posted
You'll need the following:
30mm Socket or wrench for swing arm pivot lock nut
12mm hex socket for swing arm pivot screw
Heat Gun to soften lock-tight on swing arm pivot screws
A tool to lock (hold) the fly wheel in place. Go to advrider.com wisdom where they tell you how to make one out of a U clamp. Link below:
http://advwisdom.hogranch.com/Wisdom/oilhead_tdc_mandrel.pdf
Guide pins to remove and install the gearbox. You can make these yourself. Go to Hardware store and buy four 8mm(?) 4" bolts and hacksaw the heads off and then use the hacksaw to cut a slot in end of the bolt so a flat head screw driver can fit in it to install and remove the guide pins. Take a gearbox mounting bolt with you to the hardware store to verify that 8mm is the right thread size.
You should have new clutch housing bolts and washers on hand if you're going to replace the friction plate as these are one time use only.
A clutch alignment tool is helpful but not absolutely necessary.
Have some Honda Moly 60 paste on hand for the splines.
You'll need a decent ratchet strap to lift up the rear of the bike to get the airbox out.
You'll need some Red lock-tight to reinstall the pivot bolts on the swing arm.
Posted
The two metric sockets that I had to buy to do this job, that aren't in the usual socket set lineup, were 16mm and 30mm. You'll need the 30mm for the locknut on the paralever pins. I think the 16mm was used to crank the engine over via the alternator belt pulley bolt. 1/4" and 1/2" drive allen key sockets also came in handy.
Posted
For the locating pin, you can also just use a straight bolt without having to fabricate anything. It is a 8MM bolt at least 100mm long.
For the 16mm, I had a standard socket SAE that fit right onto it. I couldn't see buying another socket just so the label would read mm instead of inches.
Posted
16mm is almost exactly 5/8"... just don't let the bolt see it... :grin:
Posted
if you have the factory tool kit, you don't need a 16mm socket. Just use the spark plug socket that is in the kit, it is a perfect fit for the crank pulley.
Posted
Seems to me that the 16mm is also used for a couple of the frame bolts???
Posted
Doc.. its in the mail this afternoon.
