Oil Lever with no Sight Glass
Traveler
Posted
My sight glass is toast. New one on order. However, I WOULD like to ride the bike.
So, other than just measuring how much oil I put in, is there an alternate way to determine oil level?
russell_bynum
Posted
If you put the correct amount of oil in, and there's no oil on the floor under the bike after it's been parked, and there's no clouds of smoke out of the exhaust when you ride it, don't worry about it.
Posted
Posted
Bounce might just be right on this one. :grin:
Posted
Go to most any auto parts store and buy a frost plug repair "kit". It is a rubber plug that expands as you tighten it. I don't know the correct size, but have seen this done along side the road. The only problem is that you can't see how much oil is in there. OK for a few hundred miles, at least.
Posted
When the oil light comes on you got trouble :-)
Posted
Measuring how much oil you put in should be fine (maybe use about 1/4 or 1/2 quart less than BMW's spec to be sure that you don't overfill.)
DavidEBSmith
Posted
You laugh, but there's an oil change place right down the street from Chicago BMW whose sign has lately read something like "Oil light on? See us." As if you're going to be getting too far beyond the oil change place with that oil light on . . .
Posted
Old School scare tactics! Oil Light On LMAO!
Oil Light on? Good Enough to Poop On! Even for Triumph the Insult Dog!
Tomas
