Best way to disable ABS fault light on R1100RT??
Shadow Rider
Shadow Rider
Posted
I have reoccuring ABS errors and the flashing lights are an anoyance. Since I don't plan to spend the money to repair the ABS I would appreciate any suggestions on how BEST to disable the flashing lights without causing any other problems in the process.
DavidEBSmith
Posted
Black electrical tape.
What is the recurring error, by the way?
Never mind, I found the other thread.
Posted
The 3 wire plug under the seat, ground the middle wire and hit the ABS switch. Should reset it. I found that by playing with the sensor spacers and being sure that there was not any crud or bits of dirt on the sensors that it would reset.
Lots o luck... :wave:
Posted
Take out the bulbs. Abd then if you're sure you don't want to fix it (like if the brain or pump is dead), take out the whole system and put on some steel braided lines.
russell_bynum
Posted
EB's solution is easier.
Posted
I was going nuts with mine on my now deceased 1100RT, found the relay under the seat was loose, pull it and reseat it. Never know....
