Turn Signal
Kevin McKenna
Kevin McKenna
Posted
Starts out normal and in a few seconds starts flashing rapidly on either the left or right... Could this be a "Flasher"?
Posted
See if it makes any difference if you have other accessories on (heated grip, high beams, etc). I believe a overall low voltage condition can also cause the problem, but I think you would typically also see it in teh ABS acting badly.
This is a problem that has been reported by quite a few, and is typically diagnosed as loose bulb sockets/wires. The signals WILL flash faster if a bulb goes out. Presumably all of the bulbs light as they are supposed to. Check and clean all bulb/sockets and connections.
I have had this problem also and am interested in seeing what the source of your problem is.
Would you please add you bike type/year to your signature?
