questions on '07 K1200GT
bimmerbeemer
bimmerbeemer
Posted
A friend just bought a '07 K1200GT and has a couple of questions:
1. Is a lift handle available for puttting the bike on the centerstand?
2. Previous owner told him he cannot charge battery via the accessory plug. So how do you connect a battery tender?
Thanks,
Al
RichEdwards
Posted
No, but the passenger grab handle on the left side works just as well.
Access to the battery on the new GT is very easy...Just remove the two screws on either side of the gas filler cap and remove the battery cover. Then attach an 18 inch cable with an SAE plug to the battery (available from http://www.powerletproducts.com/index.php?mid=0 )
The plug comes out near the handlebars and is available for charging the battery with a Battery Tender. I also use it as a connection to the battery to power my GPS.
Posted
You can charge the battery thru the accessory socket..... You just need the fancy BMW charger to do so. It activates the socket while the ignition is off to allow the charging to take place.
You can however hook a standard battery tender directly to the battery.
RichEdwards
Posted
I have that special BMW charger. It works fine with the Canbus system on my GS. It does not work on the GT.
BitScribbler
Posted
I have that special BMW charger. It works fine with the Canbus system on my '08 GT. :)
Lets_Play_Two
Posted
+1 on my '07 GT.
bimmerbeemer
Posted
Many thanks to Rich Edwards, Satguy, bitscribbler and lets_play-two for the answers. I'll pass the info on to my friend in Texas.
Al
Posted
You fellas need to ride more
Kaisr
Posted
+1 on my 06 KGT
RichEdwards
Posted
Guess I'll have to give the BMW charger another shot at the GT.
BitScribbler
Posted
I'm sure you must know this, because it's probably the same on the GS, but just in case it's useful to others...
You must plug the charger in soon after you have powered off the bike, otherwise the canbus shuts the socket off, powers down and it can't be re-enabled. By "soon" I believe it's around 30/40 seconds. Once plugged in and charging, the charger can then tell the canbus to keep the circuit open.
Posted
Hi,
Excellent info.
Much appreciated.
RP.Falcon
07 KGT
97 HD Sporty
