ChuckS Posted March 24, 2005 Share Posted March 24, 2005 What dose anyone know about this. Just talked with the dealer and there are two comming in both dark grey, fully loaded w/ on board computer, alarm and everything else.... I was thinking of red...but..??.. Thanks Chuck the inpatient... Link to comment
Jerry_75_Guy Posted March 25, 2005 Share Posted March 25, 2005 You're making a big investment here, so make sure you are happy with what you get; color, accessories, everything. You're in this for the long haul (no pun intended), so there's no reason to go half way even if you have to wait a bit. That said, I'd go for the red; nicer color and, except for color blind drivers, it should standout a little better, and give you less chance of blending into the backround like a gray bike might. Link to comment
John Bentall Posted March 25, 2005 Share Posted March 25, 2005 On board computer will calculate average speed, average gas mileage, remaining range etc. It is a must-have option if you want the low oil level warning lamp as well. I suspect dealers will specify most bikes with this equipment. P.S. Go for the dark grey, it looks gorgeous. Also blends in better with the black plastic of the chassis, frame etc. Link to comment
ChuckS Posted March 25, 2005 Author Share Posted March 25, 2005 So what do you know about the raido / cd option? Is there headset jacks? I really don't want to be blasting music like I am in the getto... I am leaning hard to the grey...got to see it first... Link to comment
Geraldh Posted March 25, 2005 Share Posted March 25, 2005 On board computer will calculate average speed, average gas mileage, remaining range etc. It is a must-have option if you want the low oil level warning lamp as well. I suspect dealers will specify most bikes with this equipment. P.S. Go for the dark grey, it looks gorgeous. Also blends in better with the black plastic of the chassis, frame etc. That's what I ordered. Hope it looks as good as everyone says! Link to comment
Gadget Magnet Posted March 26, 2005 Share Posted March 26, 2005 So what do you know about the raido / cd option? Is there headset jacks? I really don't want to be blasting music like I am in the getto... I am leaning hard to the grey...got to see it first... I did not see any headset jacks.. For the kind of money the cd player costs, you can buy yourself a 40GB Ipod and put your entire musical collection on it. You can't change cds on the go, so, every 45 to 60 minutes, you gotta pull over to change discs? As for an FM radio, these days there's more commercials than there's music.. The sound system (radi and cd) are well over $1000 option.. At any rate, hearing the music at highway speeds through the dashboard speakers is pointless.. It seems like dealers who have RT's on the floor are ordering them fully loaded to unload them onto those who can't wait for a factory order with exactly what they want on it.. Link to comment
gadgetgaz Posted March 26, 2005 Share Posted March 26, 2005 So what do you know about the raido / cd option? Is there headset jacks? No, there is no headset. I have fitted an autocom and speaker cut-off switch to send the music to my helmet speakers. It works a charm - and the best bit is that the volume increases the faster you ride Link to comment
gadgetgaz Posted March 26, 2005 Share Posted March 26, 2005 For the kind of money the cd player costs, you can buy yourself a 40GB Ipod and put your entire musical collection on it. Apparently, Becker who make the cd system for BMW, also make an aux input adapter. If you press the cd button twice the display says "AUX" and if you have the adapter and an mp3 player plugged in then the sound comes through the cd/radio system. I am researching this option myself ATM as it will fit the bill nicely. Link to comment
RodB Posted July 16, 2005 Share Posted July 16, 2005 Gadgetgaz, Sounds just like what I need. Plus if you run the bike's audio system through the comm system, all forms of music/radio can be controlled in 1 place. Have you gotten any more info on this AUX port? Rod Link to comment
gadgetgaz Posted July 17, 2005 Share Posted July 17, 2005 Tricky one that. Becker have since denied selling such a thing, it seems they have been gagged by BMW or something. There is an adaptor available for the same radio fitted to BMW cars but the volume is too low to be very useful. Check out THIS thread on this forum for info on making your own adaptor for next to nothing. It has exactly the same low volume problem. BMW and Becker are in denial. They need their butts kicking! Link to comment
axabmw Posted July 18, 2005 Share Posted July 18, 2005 With reference to adding an aux input. I have an FM Modulator on my 1150RT that fits IN the radio box. This lets you put an additional source through one of the radio channels. I think it cost about £30. The only downside I found was it tended to swamp any other stations when searching. You can always make it switchable. Link to comment
David_S Posted July 18, 2005 Share Posted July 18, 2005 gadgetgaz, if I understand correctly you have the BMW radio going to your autocom? If so what wires did you tap to get the sound. I use a different comm system but have earplug speakers and would like to connect an 1/8 inch jack to the radio speakers so I can connect it to the comm system. Thanks So what do you know about the raido / cd option? Is there headset jacks? No, there is no headset. I have fitted an autocom and speaker cut-off switch to send the music to my helmet speakers. It works a charm - and the best bit is that the volume increases the faster you ride Link to comment
gadgetgaz Posted July 18, 2005 Share Posted July 18, 2005 I use the actual speaker wires but you need some impedence matching such as Autocom's part 67. You can also get one for about £10 from a car audio shop, they are designed to feed a car power amp from a car radio that has no line-out connector. Link to comment
sideways Posted July 18, 2005 Share Posted July 18, 2005 Chuck, are you thinking about getting a SECOND new RT? Personally, I'd like to have one in every color , but I'm running out of space in the living room already! But if you are going to order one, here's my one and a half cents worth, having around 3500 miles on mine now. First, the oil level warning is a nuisance and an irritation. BMW should pay YOU for putting it on your bike. All praise the simple, elegant, sight glass! Try to get the computer, but not the stupid oil warning. Second, from everything I've heard and read, ESA really is useful and well worth the extra scratch. I thought it was a gimmick and didn't get it on my bike, but the more I learn about it, the more I wish I'd sprung (pun alert) for it. Next time I'll get it for sure - on my 2009 K1300RT! Last, there's a review of the new RT in the newest Rider Magazine wherein they complain about the BMW radio/cd player. Worth a look. Good luck! Link to comment
David_S Posted July 19, 2005 Share Posted July 19, 2005 I use the actual speaker wires but you need some impedence matching such as Autocom's part 67. You can also get one for about £10 from a car audio shop, they are designed to feed a car power amp from a car radio that has no line-out connector. Sorry for the hijack but this is probably useful info for others as well if they want to connect helmet speakers to the stock radio Do you think something like this would work if I cut the RCA jacks off and solder to the speaker wires? Link to comment
CraCol Posted July 19, 2005 Share Posted July 19, 2005 there's a review of the new RT in the newest Rider Magazine wherein they complain about the BMW radio/cd player. I have the Radio\CD, and would probably NOT get it next time around.. CD skip's easily, and radio reception is poor.. I'm using XM as my main sound system now.. Craig Link to comment
gadgetgaz Posted July 19, 2005 Share Posted July 19, 2005 David_S No that won't do the job (although it will be handy if you suffer ground loop noise). I looked on Radio Shack's site but couldn't find what you need. If it helps here is a link to the item from a UK seller http://www.maplin.co.uk/Module.aspx?ModuleNo=33176&doy=19m7 You will probably be able to find a seller near you. Link to comment
dmevid Posted July 23, 2005 Share Posted July 23, 2005 Is the speaker cut-off switch autocomm part #136 or 148p? I just purchased the Pro-7 Sport Tour Kit and forgot to order the privacy/PTT switch. Also I see a part #164 which is a hi/lo volume switch. It is a grip mounted toggle switch just like the Privacy/PTT switch. Are you supposed to mount these toggle switches on the handle bars?? thanks, Dave Eller 05 R1200 RT 02 K1200 LTE 05 1200 Sportster Custom HD Cleveland, Ohio Link to comment
Zeiser Posted July 24, 2005 Share Posted July 24, 2005 The radio used is coming from Clarion (Japanese brand). As i worked for this company, i will try to find the pining of the rear connector or, if it is available, the connector for auxiliary/intercom use Michel Link to comment
gadgetgaz Posted July 24, 2005 Share Posted July 24, 2005 Part 136 and 148 are for bike-to-bike intercoms. You need part 66 or part 67 (if you want to switch off the speakers). Link to comment
Whip Posted July 24, 2005 Share Posted July 24, 2005 No head set jacks....after market only.....BAEHR... whip Link to comment
