Back brake ablaze
bdspler
My back brake did not disingadge all the way.
but enuff to not feel a bad drag. I had just got gas and it was fine as I pushed it around the pumb to fill up.
as I head for home, and 2.5 miles down the road. I smell BURN. hoping its not me I diside to check it out.
AS I pull in a BP the dash lights go on! Brake failure and the other red one.DANG its me. as I get off the bike smoke, as I look under eek.gifthe saddle bags, FLAMES 5 " Looking more like 5'
I have a Diet sprite in the side case ...NOOOOO the OTHER SIDE case!!!!!!!!!!! I shake and aim and out goes the fire. all the wile thinking WHY did you have to TOP OFF the tank this time. the drain line was right thier.
Has anyone ever heard off a back brake not disingaging all the way. Or starting a fire?
its under warrenty...so I should be OK...I hope!
I haven't heard of it happening, but that doesn't mean much. Thankfully you caught it when you did though. Could have been a real dissaster. Glad to hear you are ok.
I've had it happen on a Jeep Cherokee front brakes coming back out of the mountains. The brakes would get hot, the pads would expand and stay stuck out. Rotors warp and the entire car shakes. Pulled over and let it rest while I ate lunch and figured out an action plan to get home. After lunch, thing cooled off and all was well for me to get home and get service on it. I was told that it was fairly common with the new pad compositions. The final answer (after it happened twice again), was to replace the cylinders.
I had it happen on my shovelhead Harley a number of years ago. At that time they had an adjustable rod that ran to the back brake. I had installed new brakes and adjusted the rod to take out excess play in the pedal. The rod ran along the exhaust pipe and, after coming up to temperature, expanded enough to not allow the brake to disengage. I had no flames but I turned the rotor a lovely shade of blue. Glad you got it put out. Sounds like the making of a good Diet Sprite commercial in there somewhere.
My 98 RT did it. Brake wouldn't release and I tried to limp it home from work. Disk got hot enough to ignite the rubber boot around the FD pivot.
Wow!
If it is any consolation, yes my back brake (1150RT 2003) for some reason hangs up. The disc has 'blued' on a few occasions. It is often heard 'clacking' as it cools down. I have posted a request on these pages and unfortunately never got to the bottom of what causes it. I have rebuilt the calipers with new pins, new slides and new rubbers. The problem is less pronounced, but still there. I don't like it, but have had to live with it 'till I get it solved. The bike rides fantastic. I declutch and it free wheels with no noticable rapid deceleration. I wheel it about, and it is no more difficult than any other bike.
I hope your dealer resolves it. Let us know what he thinks.
Andy
Does the reservoir cap have an air vent?I had this problem on a car one time,when the brakes were applied they would stick on,the fault was traced to a blocked pin hole in the reservoir cap.
On the 1150 the rear wheel circuit is fed from an independent reservoir in the ABS unit and yes it has a monstrous vent. Share with the front circuit BTW, so a vent issue would not likely cause a sticking issue on the rear only.
If it was a problem with the rear control circuit sticking on the servo whine when the brakes were not being applied would be obvious I would think.
If the caliper itself sticking is absolutely ruled out, and the servo is never on when it shouldn't be, about all that is left is a malfunctioning ABS unit. Unfortunately.
My 04 R1150R did it. I was getting close to home and I smelled burning and pulled into the driveway and it was smoking and the rear drive boot had a big hole burned in it. I took the caliper off and the brake pad just fell out in pieces. I guess the pad came apart and lodged in between. Anyway, the dealer sent me new pads out and then it still got hot so the dealer told me not to ride it and took it in and replaced the rotor; they said it was warped; they did it under warranty. I rode the bike another 40,000 miles and it was fine but for quite awhile I would feel the caliper to make sure it wasn't hot.
The rear brake caliper can lock up if the adjuster on the actuator that the brake lever pushes on is mis-adjusted. The thing can lock on and heat builds up real fast, can smoke, melt boots and aps sensors, seals in calipers, etc. This can have the same affect as pads being shot.
HairyCannonball
The right front caliper on my '05 R12RT did that..smelled it and felt it dragging before it caught fire, but it did ruin the rotor. Rotor got hot enough to turn blue. Local dealer replaced caliper and rotor under warranty. It was a mechanical rather than a hydraulic problem as the left caliper was fine and they are teed together.
Tim
Seriously, that priceless. clap.gif How old/worn are your pads? Could they have come loose/broken?
Seems unusual to replace the rear pads on a 2005 bike. How many miles were on the pads you replaced? Maybe they've been dragging for some time to wear out so soon. If not, then the fact you had new pads put on two weeks ago seems like more than a coincidence and points to a brake caliper problem rather than an ABS malfunction.
