brianbmw Posted February 7, 2008 Share Posted February 7, 2008 I'm trying to get set up to do the maintanence on my 1200ST and just want to make sure i get all the tools i need. What do you use? I was hoping i didn't have to spend $35 on an oil filter wrench and $45 on a spark plug wire puller. Brian Link to comment
keithb Posted February 7, 2008 Share Posted February 7, 2008 You can buy the oil filter wrench for $20 from Bob's BMW. You need a thin walled socket for the spark plug. Buy one and have a machine shop turn it down for you. I think BMW sells one for about $75. It is the socket and extension cast as one piece. A lot of money for a money IHMO. If you need the tool to remove the long tube that fits on the plug you can get that from www.marcparnes.com. I think it is about $25. Link to comment
brianbmw Posted February 7, 2008 Author Share Posted February 7, 2008 Thank You Brian Link to comment
notacop Posted February 7, 2008 Share Posted February 7, 2008 If it is the same as the 1100 sparky socket and puller I got a spare someone passed on to me. Yours if you want it... Link to comment
brianbmw Posted February 7, 2008 Author Share Posted February 7, 2008 This one says it's for the 1150 and 1200. DOes yours look anything like this? If so i'll take it. http://www.marcparnes.com/BMW_Plug_Tool.htm Thank You Brian Anderson 31 Cordaville Rd Ashland, MA 01721 Link to comment
keithb Posted February 7, 2008 Share Posted February 7, 2008 This link you listed pulls the long tube off the spark plug. I cannot remember what you call the darn thing. I have one and it works very well. There is another option. Get a pair of long needle nosed pliers. Wrap the tips with a shop rag. Then grab the black portion at the top of the long tube and gently use the valve cover to pry the long tube out. It is pretty easy. I used the plier method many times before I got the tool from Marc. There is a rubber ring that holds the long tube in place. Link to comment
Albert Posted February 7, 2008 Share Posted February 7, 2008 Just a quick note on the spark plug socket. I wouldn't rush out and pay to have a socket machined either. It just so happened one of the sockets in my tool box fit with no modification. I can't recall now if I use a true spark plug socket or just a deep socket of the appropriate size. Point is, if you look around you should be able to buy one off the shelf in a parts store. Link to comment
brianbmw Posted February 7, 2008 Author Share Posted February 7, 2008 I'm not worried about the socket, i can machine that down myself. I was wondering about the wire puller offer thing. Link to comment
Dick_at_Lake_Tahoe_NV Posted February 7, 2008 Share Posted February 7, 2008 This is the Spark Plug socket I use for my R1200RT--works great--and only 5-bucks. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91705 Link to comment
bobbybob Posted February 8, 2008 Share Posted February 8, 2008 And I bought a $4 16MM deep socket from Sears and ground it down a little on the bench grinder. Works great! Link to comment
Burt Posted February 8, 2008 Share Posted February 8, 2008 I'm trying to get set up to do the maintanence on my 1200ST and just want to make sure i get all the tools i need. What do you use? I was hoping i didn't have to spend $35 on an oil filter wrench and $45 on a spark plug wire puller. I bought the oil filter wrench from Motobins. Part #99205 OIL FILTER REMOVAL TOOL FOR K1200S, R1200GS, R1200RT & R1200ST (& LATEST 02400A DONIT FILTERS) £7.50 Go to their website: http://www.motobins.com/index.php Enter the part number in the upper left area. You will find the listing for the wrench. I got the spark plug wire removal tool from Mark Parnes. Link to comment
GoGo Gadget Posted February 8, 2008 Share Posted February 8, 2008 I use a strap style oil filter wrench and a flat head screwdriver wrapped in a shop rag to pull the plug wire off. Link to comment
bakerzdosen Posted February 21, 2008 Share Posted February 21, 2008 Marc Parnes plug puller. Crescent brand socket wrench tool for spark plugs (came in my set from Costco) just worked out of the box with the plugs. I bought a rather inexpensive oil filter tool from my local BMW mechanic. (roughly $20) I'll still continue to use K&N oil filters though when they're more convenient than a BMW filter to acquire. You just need a wrench for those as they have a nut on top. Link to comment
steveknapp Posted February 23, 2008 Share Posted February 23, 2008 I use a strap style oil filter wrench and a flat head screwdriver wrapped in a shop rag to pull the plug wire off. I've known a couple people who did the same and later had issues with cracks in the boot or wire that caused ride-ability issues in the rain. YMMV. The 1100 and 1150 single spark tools are very different from the coil on plug style that the dual-spark 1150's and 1200s use. Also, regardless of the socket you use, a locking extension guarantees you won't loose the socket in there. Plus it's useful for other jobs as well. Link to comment
Kitsap Posted February 23, 2008 Share Posted February 23, 2008 Snap-On tools has a thin wall socket for removing plugs. Another board member posted this info last year, I wish I could remember who so I could say thanks Link to comment
hopz Posted February 23, 2008 Share Posted February 23, 2008 Harbor Freight has a thin walled deep socket for the plugs... For the Filter, I use the expanding/contracting, ratchet sort of wrench from my Harley days...or the strap wrench that fit old BMW 2002's (cars)... Link to comment
