scushthebike Posted February 3, 2008 Share Posted February 3, 2008 I'm a BMW club member in the UK and want to post a technical problem with my R1150RS. Coming home from >> work last night, the servo system cut out leaving me only with >> residual braking. I pulled up, switched off, and the system reset >> itself. This happened twice more before I got home. I checked the >> usual suspects - fluid and battery both OK. Has this happened to >> anyone else, or has anyone got any ideas? Link to comment
ShovelStrokeEd Posted February 3, 2008 Share Posted February 3, 2008 Done a tire change lately? It is possible the ABS sensor on the front wheel is at a marginal adjustment. I'd look there first, I don't remember the proper clearance, sorry. Link to comment
T__ Posted February 3, 2008 Share Posted February 3, 2008 I'm a BMW club member in the UK and want to post a technical problem with my R1150RS. Coming home from >> work last night, the servo system cut out leaving me only with >> residual braking. I pulled up, switched off, and the system reset >> itself. This happened twice more before I got home. I checked the >> usual suspects - fluid and battery both OK. Has this happened to >> anyone else, or has anyone got any ideas? Scushthebike, did you get a dash warning light before the failure or at the time of failure? If it quit then the warning light came on or both at the same time possibly a power relay for the ABS system going out on you.. Were you using both brake levers when it quit? Or just using the front or rear lever? If only using one lever possibly a micro switch on the lever used is not making contact & starting the pump.. Next time it fails see if you can determine if the abs pump is wirring away even if you don’t have assist.. I’m guessing an ABS relay problem here or a wiring problem.. Twisty Link to comment
