Smoothing out the gear changes
pdes
Guys, I have had my new R1200RT for three weeks. It's only my second bike (ex Suzuki Bandit rider!). I've been riding like an old geezer for the past 600 miles per the stealer's instructions. I have noticed that the change-down to 2nd and first is extremely "clonky". I am assuming that this is a characteristic of the box but am a little surprised as this is deemed a luxury vehicle. Assuming that this is normal, can any of you seasoned riders give me an idea as to how to smooth out these changes as the noise from the box when changing down is quite disconcerting. Do you only engage 1st when stationary and ride the clutch in 2nd for slow manoeuvres? Thanks
Silver Surfer/AKAButters
Preload the shifter, match the revs, and don't worry about it. "Clunky," is a BMW tranny, "feature." Dang embarassing at times if you ask me.
It shifts nice and smooth right around 6000RPM and beyond! thumbsup.gif Seriously, I don't try to down shift into 1st unless coming to a complete stop or close to it. I don't think you'll find the gearbox on the RT will ever be as smooth or snickety as your Bandit's or most any Japanese bike, but I don't notice it anymore. I do notice how d@mn easy the tranny on Jodie's Ninja 650R responds. Not bad, just different.
Start riding that thing and get the revs up, you'll forget about any clunking. clap.gif
As you can tell I'm not a big fan of break it in easy.
ShovelStrokeEd
Don't back off the gas on downshifts or back off a good deal less. You want the revs to climb between changes to more closely match the speed of the input driving gears with that of the road speed the output shaft is turning.
I'll wager you are pulling in the clutch, while turning the throttle off and then attempting the shift. Just back off about half of what you have been doing and things will smooth right out. I little seat time with the new technique and it will all become automatic and you won't get any lurching or the like.
Hmm... interesting, I find the RT's transmission to be quite a bit smoother than my previous sportbike. Sounds like a shifting technique issue.
If anything, getting in to first gear from neutral can be annoying, since it doesn't always catch the gear and you can't always hear the shift. I seem to have to let a little bit of clutch out first sometimes to get things moving slightly.
ShovelStrokeEd
That works, when the bike is stationary and the clutch pulled in, all the gears in the transmission come to a stop. Dogs don't always line up with their mating notches. You can also just roll the bike forward or back a little and then try again. I use both with less clunking from rolling the bike.
OK, I missed this is class. What is preloading? Please describe the technique of "pre-loading the shifter".
Apply pressure to the shift lever before you shift, then for up-shifts dip the throttle and fan the clutch, the bike pops smoothly into the next gear. For down shifts apply pressure, blip the throttle and fan the clutch.
Andy
..... and fan the clutch.
Andy
Sorry, I don't speak Leicesterese - how do I fan a clutch up in Lancashire?
Sorry, I had slipped into transatlantic speak for a moment.
Just a quick squeeze and release, only pulling the lever part-way back, just enough to allow some slip on the clutch.
Andy
pdes, I had the same shifting issues when I got by 05 RT12, except I rarely downshift into first. With time and technique (preload, partial clutch lever pull, quick shifting) you will be shifting smooth. I am happy with all my shifts now except from 1st to 2nd, but I am working on it.
Gee,
I must have the wrong bike, mine shifts so smooth and sweet that I can't imagine anything better.
I commonly downshift by bliping the throtle. I downshift aggressively all the way down to 1st gear at almost every stop.
No complaints about shifting my RT or RS... but in all honesty the RT is superior smile.gifclap.gifsmile.gif
Really little need to blip, just don't back off the throttle at all on downshifts.
I couldn't agree more. The technique takes some practice, but once I got the hang of downshifting while slightly rolling off the throttle, I instantly improved my riding. No more lost time blipping the throttle while trying to apply just the right amount of brake lever pressure, no more clunky downshifts, no more "snatchy" downshifts, etc., etc. I normally throw my first downshift before I have any significant pressure on the brakes, and I can just keep shifting as needed to keep the revs up. When I am doing a track day or playing around in the country, I don't let the rpms drop below 5K on the R12ST unless I am coming to a halt.
By the way, I use first gear all the time when called for...I don't get why some folks believe it is only to be used when getting underway from a full stop. I want the engine 'on the cam' all the time; discovering you are at 2.5K RPM in 4th gear when you need to accelerate right now does not make for joyous riding, IMO.
LOL, it's like a whole other bike isn't it? thumbsup.gif My riding buddy rode the RT and thought it didn't go that well, as compared to his V-Strom. confused.gif He never got it above 4000RPM. I sent him out again and told him to try 6000 and up, he had a big smile on his face when he rolled up. clap.gif
