BluegrassPicker Posted January 27, 2008 Share Posted January 27, 2008 Seems to be working ok, should spring for a new one? Link to comment
T__ Posted January 27, 2008 Share Posted January 27, 2008 Seems to be working ok, should spring for a new one? Tom, every once in a while I will get a motorcycle or car battery to go over 5 years.. Usually at that age when they finally decide to fail it is quick & permanent.. You can probably go a little longer as long as it is functioning properly.. One day you will crank slightly longer or leave your lights on a few minutes with the key on & it will be history.. Twisty Link to comment
smiller Posted January 27, 2008 Share Posted January 27, 2008 If it's working OK then it's working OK I guess. But six years is way on the far side of the service life curve and it can't have much longer to go, so a proactive replacement may be a good idea depending on how inconvenienced you would be when it does die (and this age that death could be very rapid.) (Edit: Twisty beat me to it...) Link to comment
Rinkydink Posted January 27, 2008 Share Posted January 27, 2008 I think you would be fine 5-10 miles from home but b4 I went on an extended ride I would replace it. $100 vs. hours of inconvenience would seal the deal for me. Just be thankful you got 6 years--more than your $ worth out of that battery. Link to comment
ESokoloff Posted January 27, 2008 Share Posted January 27, 2008 $100 They are about 25% higher then that Link to comment
BluegrassPicker Posted January 27, 2008 Author Share Posted January 27, 2008 Putting together my shopping list for spring maintenance - just needed some enabling! Link to comment
BluegrassPicker Posted January 27, 2008 Author Share Posted January 27, 2008 Done... $99.95 w free shipping... Link to comment
Mr. Frank Posted January 27, 2008 Share Posted January 27, 2008 If you never go out of town, you can wait until it craps out. You might save about $15 by worrying about it for another year. If it craps out far from home, you will be out some more money and lots of hassle. Replacing batteries at four or five years strikes me as a good idea. Link to comment
smiller Posted January 27, 2008 Share Posted January 27, 2008 Done... $99.95 w free shipping... What battery and where? I'm gonna need one too soon... Link to comment
4wheeldog Posted January 27, 2008 Share Posted January 27, 2008 My original Beemer battery is almost 6 years old. I keep thinking that I should replace it, but it still cranks strong. I think I will get one before spring, though.....It just can't last too much longer. Link to comment
bmw_rider Posted January 27, 2008 Share Posted January 27, 2008 That is cheap insurance over losing a day on the road trying to find one. Good work. You'll be able to sleep tonight. Link to comment
T__ Posted January 27, 2008 Share Posted January 27, 2008 Thing I can’t understand is the price of batteries has gone way up reportedly due to China using most of their own lead production.. That I can understand but if that is the case why hasn’t the price of old reclaimed batteries gone up an equal amount.. The price of old batteries has gone up a little but not like new ones.. America supposedly reclaims 95% of their old batteries so the lead in them must be worth more now than it was.. Twisty Link to comment
smiller Posted January 27, 2008 Share Posted January 27, 2008 I also don't understand why the cost of car batteries hasn't gone up nearly as much (proportionately) as motorcycle batteries, considering that car batteries use much more lead. Link to comment
Tony_K Posted January 27, 2008 Share Posted January 27, 2008 The price of old batteries has gone up a little but not like new ones.. New fresh batteries are ready to go user friendly = max profit. Old batteries are toxic waste and must be delt with as such even through a reclamation process = aint worth much. simple aint it Link to comment
T__ Posted January 27, 2008 Share Posted January 27, 2008 Old batteries are toxic waste and must be delt with as such even through a reclamation process = aint worth much. Yes, but that process hasn’t changed in years so it is the same as before,, with lead being worth more now the old batteries should be worth more now also.. All that old reclaimed lead is used to produce new batteries.. Somebody’s making some big money here somewhere.. Twisty Link to comment
Tony_K Posted January 28, 2008 Share Posted January 28, 2008 Somebody’s making some big money here somewhere.. B*I*N*G*O ...and it will never be the consumer turning one in as a core. The End. Link to comment
ESokoloff Posted January 28, 2008 Share Posted January 28, 2008 $100 They are about 25% higher then that Oops. My mistake. I confused Westco with West Coast Batteries Inc. (Odyssey) I hope the Odyssey is 25% better then Westco's to justify the cost diference. Link to comment
BluegrassPicker Posted January 28, 2008 Author Share Posted January 28, 2008 A place in orlando - Search ebay for this WESTCO SEALED AGM MOTORSPORT BATTERY 12V20P You can go through their online store also, but this way let me use paypal. TOM Link to comment
MikeP1300 Posted January 29, 2008 Share Posted January 29, 2008 http://ebatteriestogo.com/merchant2/merc...duct_Code=40696 I found these guys in Dallas. Cheapest AGM I could find. Link to comment
KDeline Posted January 29, 2008 Share Posted January 29, 2008 Seems to be working ok, should spring for a new one? YES! Link to comment
philbytx Posted January 29, 2008 Share Posted January 29, 2008 Tom, If you have kept it on a Battery Tender when not in use, then it could well last longer You can check out the battery after a ride by letting it stand overnight without the charger being on. After the ride, check with a multimeter to get the voltage, then the next morning, check it again it shouldn't drop by much. Then, use a proper battery tester to test the battery under load. If it checks out fine, then it's fine....just did that with my 6 year old BMW battery which was almost like new!!! HOWEVER.....If your bike is a pre-2004, I would install the BMW remote positive terminal pieces parts just in case...I did Link to comment
bmwmick Posted January 29, 2008 Share Posted January 29, 2008 http://ebatteriestogo.com/merchant2/merc...duct_Code=40696 I found these guys in Dallas. Cheapest AGM I could find. Mike, That Universal UB12220 is all over the web at $36-$44 plus shipping. http://www.batteryuniverse.com/Sealed-Lead-Acid/Universal-Battery/UB12220 http://www.batteriesasap.com/48.html http://www.ragebattery.com/power-sonic/40696case.html (4 Batteries for $36.25 ea) How is it holding up? Sounds like it might be a new low cost battery. Link to comment
smiller Posted January 29, 2008 Share Posted January 29, 2008 Mick, Are the batteries for the 1150 and 1100 the same size (i.e. will the UB12220 fit the 1100?) Link to comment
bmwmick Posted January 30, 2008 Share Posted January 30, 2008 Mick, Are the batteries for the 1150 and 1100 the same size (i.e. will the UB12220 fit the 1100?) Yes they are. Link to comment
smiller Posted January 30, 2008 Share Posted January 30, 2008 It's made in CHINA At this rate so will your next bike. Link to comment
bmwmick Posted January 30, 2008 Share Posted January 30, 2008 It's made in CHINA Philby, You may want to check the next Exide you buy too. http://www.exide.com http://www.prnewswire.co.uk/cgi/news/release?id=70219 I believe the WestCo MK batteries are also made there. Mick Link to comment
Rinkydink Posted January 30, 2008 Share Posted January 30, 2008 Philby, I wish you luck with your 6 year battery logic. Yes, you have coddled your existing battery but I think you will in time, find the inconvenience of a "side of the road" battery problem not worth the trouble. DAMHIK Link to comment
philbytx Posted January 30, 2008 Share Posted January 30, 2008 Hey Linc, Understood...but, as I said, I properly tested the battery for loss and load but, however, I did put on the later positive terminal extension kit....Just in case Soon as I get one electrical hiccup, it's a new battery for me Link to comment
Paul Mihalka Posted January 30, 2008 Share Posted January 30, 2008 It's made in CHINA We may be getting to the point that not everything Made in China is necessarily junk. I'm sure it depends on the quality requirements and price point of the contractor. My big surprise was looking at top line Harley leather riding garments. Top materials, workmanship, zippers, details, high price, Made in China. Harley also has less pricey apparel lines, Made in China, half the quality, half the price. Established manufacturers, be it BMW, Chevy, or Toyota, if they think China in the long run can't make quality, they are making a big mistake. Think Japan first, Korea (Hyundai) second, China next? Link to comment
smiller Posted January 30, 2008 Share Posted January 30, 2008 It took Toyota about three decades to go from the butt of jokes to outselling General Motors. In today's global economy China probably won't take that long. They have achieved manned space flight and may well beat us back to the moon. Get ready for some changes. Link to comment
Wild Bill Posted January 30, 2008 Share Posted January 30, 2008 Pay me now or Pay me later!! CHANGE THE BATTERY!!! It is long over due... If you are interested in a record for battery life, buy an new battery and put it in your side case for when the original craps out!! Then you can post back and report on your battery record, and not get STRANDED in the process... Just change please!! BK Link to comment
philbytx Posted January 31, 2008 Share Posted January 31, 2008 Paul, Sorry, I was just being facetious We just had the windshield replaced on Deb's Subie (bad stone crack). The replacement was made in China...it was OEM with no optical distortion and extremely well finished. Chinese motorcycles anyone??? Link to comment
Aceboympk Posted April 9, 2008 Share Posted April 9, 2008 http://ebatteriestogo.com/merchant2/merc...duct_Code=40696 I found these guys in Dallas. Cheapest AGM I could find. Mike, That Universal UB12220 is all over the web at $36-$44 plus shipping. http://www.batteryuniverse.com/Sealed-Lead-Acid/Universal-Battery/UB12220 http://www.batteriesasap.com/48.html http://www.ragebattery.com/power-sonic/40696case.html (4 Batteries for $36.25 ea) How is it holding up? Sounds like it might be a new low cost battery. I just ordered the battery from Rage Batteries. I spoke with Jerry there. He's assured me these batteries will hold up as good as the Odyssey or WestCo. They have a 2 year warranty and he'll replace it for free if it fails before then. I told him I'm going to be the guinea pig for the battery. Trust me, I'm neverous about not buying the WestCo (Panasonic) or the Odyssey. But, I figure it can't hurt trying out a battery for $35 ($45 with two day shipping). Regards, Mark Link to comment
randy Posted April 9, 2008 Share Posted April 9, 2008 my experience maybe limited ( so please no flaming) but what is the big deal about a battery going dead. You just bump start it one time and ride to wherever. there is always a sears or other place to get a battery. Mine went out on a weekend ride. Bump start at lunch, and again next morning. Got home on a Sunday, order the battery that night on-line and had it I think on thursday. Will the new RXX series bike bump start? My comments are limited to the old oil head bikes, and my FJR. I have bump started both. Am I missing something? Link to comment
bmwmick Posted April 10, 2008 Share Posted April 10, 2008 I just ordered the battery from Rage Batteries. I spoke with Jerry there. He's assured me these batteries will hold up as good as the Odyssey or WestCo. They have a 2 year warranty and he'll replace it for free if it fails before then. I told him I'm going to be the guinea pig for the battery. Trust me, I'm neverous about not buying the WestCo (Panasonic) or the Odyssey. But, I figure it can't hurt trying out a battery for $35 ($45 with two day shipping). Regards, Mark Mark, Did Jerry say why the UB12220 is no longer available on his site? It's a 22AH battery vs the 17AH one now listed as a substitute. Does Jerry know how you are going to use it? Pretty impressive warranty for that price. I'm the guinea pig for the Universal UB12220. After 10 years of success with the Panasonics, I'm going to see how this Universal holds up. Mick Link to comment
realshelby Posted April 10, 2008 Share Posted April 10, 2008 myWill the new RXX series bike bump start? My comments are limited to the old oil head bikes, and my FJR. I have bump started both. I recently had my 1 year old Panasonic fail while at work. Kind of flat here in Houston so no hill to drift down. I could not muster enough speed to jump on bike, upshift a couple gears, and let clutch out just as my weight hit the seat. RT's are heavy! Couple co-workers came out to help. Would not start in 2nd gear-just scooted rear tire. 3rd gear worked only when I hit the seat with my weight just right. Yes, they will bump start. But it would be a $%#& site easier if I had a hill to drift down! Link to comment
randy Posted April 10, 2008 Share Posted April 10, 2008 good point made, yes we have very nice hills here in GA and NC. so yes in both cases I had a nice slope to go down, and had a partner with me to help push. i.e. I did get a good "roll" going. Thanks for helping to qualify my comments. Link to comment
