butterbutt Posted January 24, 2008 Share Posted January 24, 2008 I am looking for some guidance in reguards to powering my Valentine V1. I do not want to use the 12V "cigarette" adapter. I would rather hardwire it to the centec fuse panel. Could someone direct me to the proper post. My searches have been unsuccessful. Link to comment
Rocket_Cowboy Posted January 24, 2008 Share Posted January 24, 2008 Do you have the hardwire adapter for the V1? If you've already got the Centech installed, it's very straight forward. I've got mine wired to a Touratech Canbus helper that is then fed into the Centech ... basically the Touratech block is just a switched fuse block, where the Centech is always hot. Same net effect. Link to comment
butterbutt Posted January 24, 2008 Author Share Posted January 24, 2008 Do you have the hardwire adapter for the V1? This is probably what i am looking for. I did not find one on the Valentine web page. Link to comment
butterbutt Posted January 24, 2008 Author Share Posted January 24, 2008 Found it. Was not looking under the correct tab. Thanks Link to comment
Gregori Posted January 27, 2008 Share Posted January 27, 2008 If you bought it new, the V1 should have had the hardwire adapter in the box when you got it - take a look there before buying another one! Link to comment
