flexibleflyer Posted November 26, 2007 Share Posted November 26, 2007 I have a R1200ST, and I am adding additional LED brake lights, and flood lights for the front - I have heard that this may be a drain on the battery - a friend of mine has a different bike, and has lights, plus wears a heated vest and has had this problem. Should I be concerned, and is there anything I can do to avoid having a problem. Thanks, Bob Link to comment
Ken H. Posted November 26, 2007 Share Posted November 26, 2007 Not a problem. The electrical system can easily handle most anything you add to the bike. (Presuming connect wiring, additional fuse block, etc.) As a matter of fact it's one of these bikes strongest points. Additional stuff on our GS (which has a smaller alternator than the RT): 2 sets of aux driving lights, 2 heated seats, 2 sets of heated jackets and gloves, GPS, Autocom, FRS radi0, additional LED lighting, and more. No issues. Link to comment
Rocket_Cowboy Posted November 26, 2007 Share Posted November 26, 2007 The LED lights pull hardly any power at all. The biggest power drain you might have would be the flood lights, and just how big of a power draw would depend on the bulb wattage used. You don't mention what your friends bike is/was, but he could easily have had a problem due to alternator size on his bike. Not much of a problem on BMWs. One of the reasons I sold the Busa that I was touring on was because of the limited alternator output. Link to comment
Bowenman Posted November 26, 2007 Share Posted November 26, 2007 The ST has a 750W alternator. You can run some serious kit with that with no issues Link to comment
flexibleflyer Posted November 26, 2007 Author Share Posted November 26, 2007 FYI - my friend's bike is a BMW 650 GS - thanks for the input - I haven't put on the flood lights yet - will let you know if I have any issues after installing. Bob Link to comment
Jim VonBaden Posted November 27, 2007 Share Posted November 27, 2007 Tina runs Motolights, P3 LED tail lights, GPS and Gerbings all at once, and has never had an issue. I run similar, plus an additional set of gerbings, and an additional set of driving lights on occasion, and no issues, even with the Servo-ABS. Jim Link to comment
paulcbrowne Posted November 28, 2007 Share Posted November 28, 2007 I owned a 650 GS that I sold last year. You need to be careful about the electrical load. I dropped my H7 Hella FF50's for smaller H3 lights and dropped to 35 w bulbs. I installed a voltmeter. I could run my Gerbing jacket liner, but had to turn off the lights at a long stoplight. While running, I could run the Gerbings, heated grips and lights. Idling alternator output is weak on the 650. Link to comment
RFW Posted November 28, 2007 Share Posted November 28, 2007 I have a R1200ST, and I am adding additional LED brake lights, and flood lights for the front - I have heard that this may be a drain on the battery This is clearly not a problem. LED brake lights (or any brake light for that matter) consume far to little current to even be noticed by your alternator. An LED brake light uses around a Watt or two at most. Your alternator can pump out hundreds of Watts. As you can see, this is a non-problem. Link to comment
