motoleo Posted November 24, 2007 Share Posted November 24, 2007 I have a 1999 R1100RT and I'm looking at buying a windscreen from a 2004 R1150 RT. Will the 04 windscreen fit my 99? Link to comment
Linz Posted November 24, 2007 Share Posted November 24, 2007 Could you get a refund if it didn't fit? AeroFlow have two models, one for 1100 and one for 1150. Others report that they fit exactly from one model to the other. I'd like an Aeroflow for my 1150 but I can only ever find good used ones for 1100's. Also interested in the answer... Linz Link to comment
motoleo Posted November 24, 2007 Author Share Posted November 24, 2007 Could you get a refund if it didn't fit? AeroFlow have two models, one for 1100 and one for 1150. Others report that they fit exactly from one model to the other. I'd like an Aeroflow for my 1150 but I can only ever find good used ones for 1100's. Also interested in the answer... Linz I'm trying to avoid a return or fit problem up front before I actually buy the windscreen. Link to comment
KMG_365 Posted November 24, 2007 Share Posted November 24, 2007 I know the holes line up and I believe the mounting brackets will work at least one way because I've switched screens with another rider on an 1100 on a trip. There is a difference between the 1100's and the 1150's with regard to how they mount and IIRC one having/requiring an extra hole between the other two (top and bottom). Mine was a Cee Bailey's and I think his was a stock 1100 screen, but I believe all the after market ones have the extra holes in the middle, so as long the hole is there (if in fact it is needed on the 1100) then you should be good to go. Link to comment
motoleo Posted November 24, 2007 Author Share Posted November 24, 2007 Thanks for the info KMG_365. Link to comment
RBowen Posted November 24, 2007 Share Posted November 24, 2007 Morning, You can't go wrong with CeeBailey , I have loved mine!! Randy Bowen Link to comment
motoleo Posted November 24, 2007 Author Share Posted November 24, 2007 The one I'm looking to buy is a stock windscreen and I am going to use it in the summer to replace my original windscreen that has a plastic film on it that is flaking off. I have a Cee Bailey's that is wider and taller that I use for the colder months. Link to comment
Al Navecky Jr Posted November 25, 2007 Share Posted November 25, 2007 I have a 1999 R1100RT and I'm looking at buying a windscreen from a 2004 R1150 RT. Will the 04 windscreen fit my 99? NO IT WILL NOT FIT!! I tried a 04 Cee Bailey on my 00 and the mounting hole are about 1/4 too wide. Called Cee Bailey and they said it would not fit. Link to comment
Joe Frickin' Friday Posted November 25, 2007 Share Posted November 25, 2007 I have a 1999 R1100RT and I'm looking at buying a windscreen from a 2004 R1150 RT. Will the 04 windscreen fit my 99? NO IT WILL NOT FIT!! I tried a 04 Cee Bailey on my 00 and the mounting hole are about 1/4 too wide. Called Cee Bailey and they said it would not fit. Are all 1150RT's the same, or did they make a dimensional change somewhere between the first and last model years? I bought a used windscreen many years ago that fit my 1100RT; the seller owned an '02 1150RT, although I'm not certain whether the windscreen came from his bike or not. Link to comment
Al Navecky Jr Posted November 25, 2007 Share Posted November 25, 2007 I have a 1999 R1100RT and I'm looking at buying a windscreen from a 2004 R1150 RT. Will the 04 windscreen fit my 99? NO IT WILL NOT FIT!! I tried a 04 Cee Bailey on my 00 and the mounting hole are about 1/4 too wide. Called Cee Bailey and they said it would not fit. Are all 1150RT's the same, or did they make a dimensional change somewhere between the first and last model years? I bought a used windscreen many years ago that fit my 1100RT; the seller owned an '02 1150RT, although I'm not certain whether the windscreen came from his bike or not. It is ONLY the 2004 1150RT and up that is different. Cee Bailey's web list for 1996 - 2003 and 2004 - UP. Link to comment
