Don_Eilenberger Posted November 21, 2007 Share Posted November 21, 2007 Garmin recently sent me an email offering for $69.95 - a 2008 map update disk for my StreetPilot 2720. Anyone gotten one yet and what's your experience with it? Link to comment
twilmotte Posted November 21, 2007 Share Posted November 21, 2007 I upgraded to CityNav 2008 and it works fine with the Garmin unit, BUT ... it does not calculate routes properly on either of my computers (running Windows XP). I have talked to Garmin tech support several times, and they even sent me another copy of the City Nav 2008 software ... same problem. The last time I talked to them, they said they are aware of the route calculating issue. (Hopefully, they will be issuing a fix update soon.) So, if calculating routes on your computer and downloading them on the Garmin is important to you, you may be disappointed in City Nav 2008. BTW, I am working around this problem by using two 2GB memory cards, one with CNNA 2008 on it and one with the older version of City Nav on it. I just switch the cards, depending upon how I am using the unit. Anyone else discovered route calculating problems using your home computers? Link to comment
Don_Eilenberger Posted November 21, 2007 Author Share Posted November 21, 2007 Tom - from what I understood the email said - it's not "City Nav" - it sounds as if it's a complete replacement for the embedded maps of the US/Canada that are in the 2720 (it has no memory "card" and all the maps are fully preloaded..) Link to comment
topdal46 Posted November 22, 2007 Share Posted November 22, 2007 I have a MacBook laptop and I used it to update my 2720 about a month ago, update was easy to install. Apparently i'm missing something, in that with a Mac computer I can not do any route planning on the computer, all I have available is what I can do on the GPS unit itself. Link to comment
hopz Posted November 22, 2007 Share Posted November 22, 2007 FYI to others. Mapsource and City Navigator come with various Garmin units. Mapsource is the software that communicates between the PC/Mac based maps and the GPS units. Garmin released the latest update to Mapsource this week. Version 6.13.5... there is no charge for the Mapsource updates. Link to comment
rickmoen Posted November 22, 2007 Share Posted November 22, 2007 Mapsource 6.13.5 STILL requires a Windows-based PC to run. It does support Vista, however. Native Macintosh support is still non-existent. Link to comment
hopz Posted November 22, 2007 Share Posted November 22, 2007 rick is correct about the Mac and mapsource- I mis-spoke. However the Garmin POI Loader works on a Mac- for what its worth. Link to comment
Scarver Posted November 24, 2007 Share Posted November 24, 2007 Anyone else discovered route calculating problems using your home computers? Yes, I confirm that problem and also conveyed it to Garmin. Simple test case was to route from downtown Houston to downtown Dallas. With no Avoids and Faster time it will select IH45. Add "Avoid U-turns" and it will route you through Waco and add over an hour to the trip. On V8 it barely changed the estimated time. Link to comment
Bob_Mc Posted November 26, 2007 Share Posted November 26, 2007 The City Navigator North America NT Map Update 2008 DVD is available at Best Buy for $79.00. I got mine last month for $69.00. The update is good for a long list of Garmin units, but you can only update one unit with it. Link to comment
rickmoen Posted November 26, 2007 Share Posted November 26, 2007 There are two versions of City Navigator 2008. An NT version and a (more expensive) non-NT version. I don't know what the difference(s) is/are, except for the units each version works on. Be careful what you order or buy. Link to comment
SageRider Posted November 26, 2007 Share Posted November 26, 2007 There are two versions of City Navigator 2008. An NT version and a (more expensive) non-NT version. I don't know what the difference(s) is/are, except for the units each version works on. Be careful what you order or buy. The NT version data is essentially stored at a higher compression, enabling one to fit more maps into the same amount of memory than the non NT version. Link to comment
rickmoen Posted November 26, 2007 Share Posted November 26, 2007 Thanks for the info! Never to young to learn something new! Link to comment
