Rob F. Posted November 21, 2007 Share Posted November 21, 2007 Is the shifter adjustment done by loosening the torx bolt and repositioning the lever to the desired position or is there more to it? It looks like a 6mm wrench will fit. I put a larger cover/extender on it to give me more "feel" but now it is a little bit high and in the way so I want to lower it. Thanks. Link to comment
Jon_M Posted November 21, 2007 Share Posted November 21, 2007 Yeah, just move it on the spline until you have it where you want it. There is also a turnbuckle thingy under the tupperware that can also be used for the same purpose. I think it gives you a little finer adjustments. Link to comment
