MattP Posted November 20, 2007 Share Posted November 20, 2007 My rear tire is worn, but I'm not sure how how many miles it has on it (purchased the bike used with it on) and I'm not sure how far to let it go. It's a Road Pilot and the center setion doesn't have a prominent tread pattern, but what it does have is pretty much worn down. There is considerable tread left on the sides. It rides fine, grips well and there are no cords or anything like that showing. My question, I guess, is: How far can I ride on this one? I have heard "till the cord shows", which pretty much fits my budget model but I don't want to be stupid either. Thanks for the input. Link to comment
jaytee Posted November 20, 2007 Share Posted November 20, 2007 Once I notice shouldering (i.e. squaring-off of the center tread relative to the sides) I begin feel that on agressive corners I 'fall-in' to the corner rather abruptly. That is the sign to get a new tire. The difference in the confidence and smooth cornering ability in a new rounded tire to an old squared-off tire is amazing, IMHO. And of course the wear bars tell the rest of the story. JT Link to comment
Tony_K Posted November 20, 2007 Share Posted November 20, 2007 I don't think I have seen PR go to cord. They are just not that kind of tire. They also dont have prominent wear bars. like JT said they will go way square like a 2x4 That effects turn in a lot. Texas... turns?... you make the call. Just remember you only have 2 tires. Link to comment
Mr_Ed Posted November 20, 2007 Share Posted November 20, 2007 When in doubt, change it out. Like one already pointed out you only have 2 tires...besides... riding isn't as much fun when you're wondering about how much tire is left. Link to comment
tallman Posted November 20, 2007 Share Posted November 20, 2007 http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=51 2 tires 1 life Link to comment
notacop Posted November 20, 2007 Share Posted November 20, 2007 The tire dudes put little bumps in the gooves. When you can see those things even with the tread, it's time for money to be spent. Or you can do the 'Do you feel lucky' thing. Link to comment
IanW Posted November 20, 2007 Share Posted November 20, 2007 1. Get a tyre tread depth guage and read your manual. 2. 80% of flat tyres occur in the last 20% of tyre life. Ian Link to comment
TomfromMD Posted November 20, 2007 Share Posted November 20, 2007 And when you get your tread gauge, think about replacing the tire when the tread drops below 3/32" at any point on the tire. Definitely replace when its down to 2/32". Tom Link to comment
bobbybob Posted November 20, 2007 Share Posted November 20, 2007 I just went thru this so here's my anecdotal (07 R1200RT). I always check rear tread before riding when I think it's getting kinda low. On Sunday, it looked just like it did Sat., which was smooth in the center (Metz Z6's don't have grooves that extend into the center strip, OR wear bars), nothing showing. It had 9,100 miles on it but as far as I knew it might have another 3,000 left..who knows? I then rode approx. 2 hours/120 miles and when I returned I checked it again because it just seemed to be handling kinda squirelly. The steel belt was now showing *big* time in 2 strips around the tire, over probably 50% of the circumference. I also noticed a *very* fine piece of wire (not much thicker than a strand of elec. wire) stuck into the smooth surface--hard to imagine it even working it's way into the surface it was so thin. I pulled it out with pliers and immediately air started flowing! I could feel it and when I spit on it, bubbly. In 120 miles I had gone from a possible 3,000 mile tread life (in my ignorant opinion) to zero, a hair's-breadth piece of wire away from a flat tire (or blow-out). Once the air leaked down low and I pressed in on the center of the tire, it felt as thin as paper--and just an inch to the left or right it felt nice and thick. Those 42 lbs of air pressure were fooling me into thinking I was riding on something solid. If I had hit a sharp rock I could have easily had a blow-out. That nice tread on the shoulders of the tire wasn't helping me a bit, just fooling me into continuing to ride on "may-pops". About 1 hour ago I replaced it with a Pilot Road (which DOES have tread in the middle). I learned about riding from this. Never again! Link to comment
MattP Posted November 21, 2007 Author Share Posted November 21, 2007 Thanks for the info, all. Off to the shop, rear wheel in hand! Link to comment
bobbybob Posted November 21, 2007 Share Posted November 21, 2007 Forgot to mention one other thing I learned. I always check air pressure with a gauge before leaving the house on a ride, but I also have always "kicked" both tires before starting off again during the same ride (i.e. after a pit stop) to make sure they aren't low on air. Well, that just don't work no mo. Cause while I was letting the air leak down in my punctured tire, I kicked it after about 4 hours and it was still hard as a rock. DANG--maybe it wasn't leaking after all...?? Put the tire gauge on it---had 10 lbs of air. But hard as a rock. So much for kicking tires... Link to comment
Bill_Walker Posted November 21, 2007 Share Posted November 21, 2007 Well, my recent experience was with a Tourance, not a PR, but I'd say when you start wearing down the wear bars, the tire can go to the cord in just a couple hundred miles. Of course, I thought I had a lot more than that when I left home for DV, but I came up short. Link to comment
elkroeger Posted November 21, 2007 Share Posted November 21, 2007 I always let mine go WAY too far. Not on purpose though. Link to comment
