R1150RT and Autolite 3923 plugs
Linz
The standard Auto Lite 3923 is gapped at .32- .34 the Single Platinum AP 3923 is gapped at .36 - .38 which I just installed and they are great! I don't know what the double platinum APP plugs gap at but suspect they are even wider at .38 -.40. I got the standards and the single AP plugs in two packs at Walmart in plastic packs already gapped at the above. My Walmart did not have the DOUBLE APP so I can not say what they come at and if as some one earlier mentioned that they need higher voltage to jump the wider gap. I am having no problems with the single AP 3923 (actually works slightly better than the reguler 3923 which was a big improvement over the BMW plugs in the bike). AndyT
  • 3 weeks later...
for those of you in Oz, just got some APP3923s from :
Noel Comerfords Auto Parts
366 Edward St
Wagga Wagga NSW 2650
Ph: (02) 6925 3777
Fax: (02) 6925 1948
see online store
yes better....really!!
surging is reduced
bike feels better
still need to see how it runs in longer term
btw, gap set to 1.0mm
cheers jeffm
Just to put in my 2 penn'orth, having read the thread from end to end, I thought, "why not ?". The only ones I could source were xp3923 (iridium), they arrived and I took them out of the box and put them into the bike (2001 R1150RT) with no adjustment.
The difference is astounding !
How can a pair of spark plugs make such a huge difference ?
Idle much smoother, pulls better and surge is hardly noticeable now.
Suffice to say I will not be using any other type of plug in future.
Thanks to everyone for sharing this info.
Regards
Dave
They don't. You have been assimilated. Nothing to see here...move along...
