lovemimoto Posted November 13, 2007 Share Posted November 13, 2007 Hello fellow raiders. Does everyone know how to fix the oil level indicator on my 96 1100 gs. I juust found a small leak right in there. Any suggestion? Thanks Marcelo Link to comment
Paul Mihalka Posted November 13, 2007 Share Posted November 13, 2007 Buy a new oil window part. Drain the oil - prepare for a oil change. Drill a small hole in the center of the oil window. Take something like a wood screw and really heat it up - like on a flame. Screw it into the window. Pull the window out. Insert the new window. Best way I found is to push it in with the right size of socket. Finish the oil change Link to comment
lovemimoto Posted November 13, 2007 Author Share Posted November 13, 2007 Hey Paul! Thanks so much for the instructions. Tomorrow I will buy the part and then replace it. I let you know if I got it right. Thanks again! Marcelo Link to comment
