NoHeat Posted November 12, 2007 Share Posted November 12, 2007 I always reset my trip odometer when I refuel. Usually it works just fine. However, twice in the last 6000 miles it got stuck at 99.9 miles. That's about a 1/20 rate of incidence. It happened again today. After about 15 miles of watching it sit at 99.9, I reset it again and watched it accumulate miles. A hundred miles later it turned over to 100.0 and continued upward just fine. I have no problem with the main odometer or speedometer. Just the trip odometer. Any ideas? Link to comment
Tony_K Posted November 12, 2007 Share Posted November 12, 2007 I have taken apart my fair share of mechanical drive speedos and they are all pretty much the same. Driven by a plastic wheel gears. It is possible in your series of numbers there is a nicked tooth or mucked up tooth when the combination gets to 99.9. Resetting to 0 clears it of course and maybe when they roll around again and it does go past 99.9 the problem gear grabbed just enough to slip by. Link to comment
Bill Dennes Posted November 13, 2007 Share Posted November 13, 2007 Try resetting the odometer to 99999.9 instead of to zero. This forces the whole shebang to roll over to zero after 1/10 mile, keeping the trip odometer useful. Might unbind your problem. Link to comment
CaptainKcorb Posted November 13, 2007 Share Posted November 13, 2007 Another simple thing to try is after running the speedo back to 0.00 (by turning it CCW), turn the reset knob SLIGHTLY back clockwise. This seems to take the pressure off the number wheels and ease operation. I had issues with the numbers not aligning properly after reset and this little tactic solved it completely. Much easier than a rebuild. Link to comment
Mark K Posted November 14, 2007 Share Posted November 14, 2007 .....After about 15 miles of watching it sit at 99.9, I reset it again and watched it accumulate miles. A hundred miles later it turned over to 100.0 and continued upward just fine. Any ideas? Here's an idea......take me with you the next time you pass 100 miles twice in a day! Where are you headed? Link to comment
